Outdoor Smoke & heat detector wanted
Its worth mentioning that this is not a good time at all for companies to be designing new nodes.
A lot of microcontrollers are very difficult to get hold of these days. For the example mentioned above, I wanted to use an ATmega4808 as it has more memory than the more familiar ATmega328P a device which can be borderline, memory wise, for some applications.
Currently Farnell\Element 14 dont expect supplies of the ATmega4808/9 until early May 2023.
Hello, I made a lot of ā€œuselessā€ DIYs , recently I’m playing with Seed-E5 Lora SOC modlue + BME680 T/H/P/AQI gas sensor, together with TTN and cayenne_lpp. I saw your post just now, and checked my DIY sensor found it quite sensitive to matches’ smoke. Maybe this time my DIY is not useless, but can helps you.
Please give me a meassage if you are still working on this topic.
Lora_AQI_Tag
Sensor_Inside
