Node based on Raspberry?
link isnt broken, it was correct at the time or writing a year ago. TTN urls have changed and that has made it invalid. The page is still there on a new url https://www.thethingsnetwork.org/community/thatcham/post/pi-zero-node
Hi, I am currently in the same position where my program is giving: EV_JOINING. Is there anyon who got any progress?
Cu, Remko.
@pe1mew Just double check your appKey, appEui, and devEui and make sure that your appEUI is reverse ordered :slight_smile:
Hi @cambierr, that is in the right order.
Can you double check that devEUI, appEUI, and appKEy shown just before EV_JOINING are the same as the one shown in your TTN console ? I just tested with a clean PI2 + RFM95W and I got no problems
HI @ernestopace
I hope you can help me out with the pinouts.
My radio is a InAir9B and I have connected it up like this:
9B -> pi (Pin#)
SI -> MOSI (#19)
SO -> MISO (#21)
CK -> SCLK (#23)
CS -> GPIO6 (#22)
RT -> GPIO0(#11)
DO ->
D1 ->
D2 ->
D3 ->
How does the above relate to:
// Pin mapping
lmic_pinmap pins = {
  .nss = 6,
  .rxtx = UNUSED_PIN, // Not connected on RFM92/RFM95
  .rst = 0,  // Needed on RFM92/RFM95
  .dio = {7,4,5}
When I run TTN sample: ( Comments?)
[1b5e] (1489220428) Sat Mar 11 08:20:28 2017
[63607] (1489220448) Sat Mar 11 08:20:48 2017
OP_TXRXPEND, not sending[c5086] (1489220468) Sat Mar 11 08:21:08 2017
OP_TXRXPEND, not sending[126b04] (1489220488) Sat Mar 11 08:21:28 2017
OP_TXRXPEND, not sending[188582] (1489220508) Sat Mar 11 08:21:48 2017
OP_TXRXPEND, not sending[1ea000] (1489220528) Sat Mar 11 08:22:08 2017
Thanks in advance.
Marcell
I took a chance and connected the pinouts like this:
9B -> pi (Pin#)
SI -> MOSI (#19)
SO -> MISO (#21)
CK -> SCLK (#23)
CS -> GPIO6 (#22)
RT -> GPIO0(#11)
DO -> GPIO7(#7) - amended
D1 -> GPIO4 (#16) - amended
D2 -> GPIO5 (318) - amended
D3 ->
This gave me this:
Event EV_TXCOMPLETE, time: 6
[62c72] (1489221370) Sat Mar 11 08:36:10 2017
Event EV_TXCOMPLETE, time: 25
[c470e] (1489221390) Sat Mar 11 08:36:30 2017
Event EV_TXCOMPLETE, time: 45
[1261ab] (1489221410) Sat Mar 11 08:36:50 2017
Guess Iā€™m on the right track with the node.
Hi
I get this error with Dragino LoRa/GPS Hat 1.1 and Raspberry 3:
OP_TXRXPEND, not sending[4f984c] (1489955694) Sun Mar 19 21:34:54 2017
or:
[386a] (1489955815) Sun Mar 19 21:36:55 2017
OhOh. Unknown interrupt flags for FSK
FAILURE
radio.c:630
Sometimes it sends one packet. What could be the solution?
Thank you
Is there a Dragino Lora/GPS Hat node code for raspberry with bcm2835 library and not with OTAA but ABP?
Thank you
Iā€™m facing the same issues as you describe.
As you can see, all values corresponds with the TheThingsNetwork Console, but ttn-otaa hang on EV_JOINING.
Also the spi-scan reports correctly the Dragino GPS/Lora HAT
Anyone with some suggestions to try? Could this mean there isnā€™t any Lora-gateway reporting to the TTN? According to the TTN-Map there should be multiple TTN-Gateways in range on our university campus.
Using a Raspberry Pi 3 Model B with the latest Raspbian.
It depends on how this gateways you see on the map are configured. As someone mentioned above, e.g. single channel gateways wouldnā€™t might not work with OTAA.
Maybe just for testing you could try ABP as activation, just to ensure, that not your node is the problem.
I also ordered a Arduino module from Dragino. Lets try if this will give better results. Otherwise Iā€™ll setup the Rpi + Dragino HAT as Single Channel gateway.
Keep you posted.
BTW, does somebody found a nice library/framework for the Dragino Rpi HAT?
I implemented Hardware Abstraction Layer (HAL) code for LMIC 1.6 targeted to Raspberry Pi for Dragino GPS/Lora HAT.
Having that done, I now can use LMIC 1.6 and this HAL to write node applications on the RPi.
  • Joining the TTN using OTAA works using a fully-functional Kerlink IoT Gateway(LMIC examples/join)
  • Sending periodic sensor values to TTN works (LMIC examples/periodic)
I plan to provide the code for the HAL on github soon.
Ok it turns out that the nearest gateway (400 meters away) has a really poor RSSI and SNR valuesā€¦
I just ordered bigger antennaā€™s (5dBi), because Iā€™m unsure if the low link budget is due to my setup (Dragino Rpi HAT and Dragino Arduino Shiel with the same antenna) or itā€™s due to the poor gateway setup at my university.
Guys
As suggested @matthijs here increasing clock error for receive windows solved all my OTAA join with LMIC (on Arduino Zero) but may apply on RPI, worth trying this fix (here 1% error more) you can con even on 2% or 3%
Works perfectly with Loraspi board with RFM95
For users of a Dragino LoRa/GPS HAT (for Raspberry Pi) I have implemented a Hardware Abstraction Layer for the IBM LMIC 1.6 communication stack. This is similar to the solution of Ernst de Vreede, but as a difference it is based on IBM LMIC 1.6, which seems to be the most recent version of this communication stack. I tried not to touch the LMIC stack itself but only provide a HAL for RPi + LoRa HAT. I also tried not to put too much CPU load on the RPi when waiting for incoming messages.
Find the code in github at https://github.com/wklenk/lmic-rpi-lora-gps-hat
The following LMIC examples are working yet with this HAL and TTN:
  • examples/hello - Not using radio at all
  • examples/join - Join the TTN using OTAA (over the air activation)
  • examples/periodic - Join and periodically send a sensor value to TTN.
I would appreciate to get feedback if this stack also works for you, and if it was easy to use this piece of software.
Note: I tested it with a Kerlink IoT Gateway. Single Channel Gateways wonā€™t work.
Iā€™ll test this next week more extensively!
Quick look: https://github.com/wklenk/lmic-rpi-lora-gps-hat/blob/master/examples/ping/main.c still contains your keys/ids!
You my friend are a legend for making it clear that it will only work with a proper gateway. I struggled for days to get nodes working with single channel gateways :slight_smile:
I use the LMIC stack for some nodes, and it works great with my single channel gateway!
Your SGC works great. Is there any chance that you port it to Pi 1/2/Zero?
