No available Integrations when using Meshed
I am in Australia. When I register an Application using the meshed-handler (the things.meshed.com.au) and then try to apply an integration, the following message comes up:
“There are no available integrations for handler meshed-handler. Check back later!”
Why no integrations? I have checked back and the same message persists. I found integrations under the Asian handler. Any advice will be appreciated!
Where are you trying that?
