My First LoRaWan Gateway
Keep in mind: ADR only works for stationary nodes. When a node is moving the network will not be able to calculate correct values for the node. Any value calculated by the network might result in the node transmitting at a spreading factor and power that is inappropriate for the next location (and will result in packet loss).
Thanks Marcelo, hope all is running very fine!
hello marcelo
i am name is david mbemba student at tut in south africa , am right now busy to do the implementation of lorawan in agriculture but am relly stuck abiut how to set up my gateway am using the seeeduino lorawan kit (http://wiki.seeedstudio.com/LoRa_LoRaWan_Gateway_Kit/#faqs)…please i need help
I use this on several of my GW’s…select jac’s MP forwarder when building/installing as best option :wink: Charles & Jac make a formidable team when their solutions are combined :slight_smile:
