Hi Cliff, would you mind updating your table that or the n-fuse card is now available in 868 Mhz and 915 Mhz variants?
sure, no problem
Hi, are the n-fuse really already available as in they’re already in stock and ready to ship?
The website says “Available in Q3 2018.” which is a bit confusing. Also if they are ready maybe you should update the 3D render to an actual photo as it gives it more credibility. Thanks!
Sorry that is a leftover on the website, they are all in stock.
For the LRWCCx-MPCIE and an mPCIe to USB adapter, there is now a Windows Application called “PicoGW UI”. With this you can set up a Gateway (also TTN compatible) under Windows quickly. There is a ZIP file with the software and a user guide downloadable on the product page.
Hi Cliff!
Thank you so much for your list. I found it very interesting and useful.
Gatintelligent MPCI-GW2
mPCIe card and Raspberry-Pi adapter board.
The card seems to be manufactured by Rejeee http://njrjzn.com/pd.jsp?id=10#_jcp=2 or RAK Wireless
Semtech SX1302C868GW1 and SX1302C915GW1
based on the new SX1302
236€ on Mouser and Digikey
