@Halfbrain Working on getting your program working and so as you suggested I will follow your instructions EXACTLY.
To that end I have:
mDot
Conduit Setup to poly packet forward to TTN
MAX44009
MPU9250
BME280
So I would like to start by getting ONE of these working.
I will choose MBM280 to start
That would be APPLICATION_MODE_3
I have your program setup as follows:
main.cpp
#include “Application.h”
#include “ApplicationConfig.h”
#include “UARTTunnel.h”
int main() {
Application application;
application.init(APPLICATION_MODE_3);
while (true) {
//sleep();
return 0;
and
ApplicationConfig.cpp has LORA_MODE_1
case APPLICATION_MODE_3:
setStateTaskLight(SLEEPING);
setStateTaskTemperature(RUNNING);
setStateTaskPressure(RUNNING);
setStateTaskHumidity(RUNNING);
setStateTaskAcceleration(SLEEPING);
setStateTaskGyroscope(SLEEPING);
setStateTaskTesla(SLEEPING);
setStateTaskProximity(SLEEPING);
setStateTaskGPS(SLEEPING);
setStateTaskLoRaMeasurement(SLEEPING);
setMAX44009_MODE(MAX44009_MODE_1);
setBME280_MODE(BME280_MODE_1);
setMPU9250_MODE(MPU9250_MODE_1);
setSI1143_MODE(SI1143_MODE_1);
setuBlox_MODE(uBLOX_MODE_3);
setLORA_MODE(LORA_MODE_1);
break;
Then in in LoRaConfig.cpp - Only change is LORA_SUBBAND_2 as that is what has always worked for my TTN setup
case LORA_MODE_1:
setNetworkPublicity(true);
setActivity(true);
setFrequencySubBand(LORA_SUBBAND_2);
setSpreadingFactor(LORA_SPREADING_FACTOR_8);
setTxPowerdBm(LORA_TX_POWER_16_DBM);
setAcknowledgeRetries(LORA_ACKNOWLEDGE_RETRIES_0);
setJOIN_MODE(OTA);
break;
and lastly
static uint8_t LORA_APP_EUI[] = { 0x08, 0x09, 0x00, 0xD0, 0x7E, 0xD5, 0xB3, 0x70 };
static uint8_t LORA_APP_KEY[] = { 0x21, 0x12, 0x20, 0xC3, 0x97, 0x70, 0x8D, 0x5E, 0x64, 0x20, 0x0E, 0x9C, 0xFC, 0x6C, 0x3F, 0xCF };
static uint8_t LORA_DEVICE_EUI[] = { 0x36, 0xBF, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00 };
Which should match this TTN OTAA setup:
![](https://www.thethingsnetwork.org/forum/uploads/default/original/2X/e/ea0cc94e55f1c14c9f6eb51e1979684df90cab56.png)
Also commented out s1143
void Application::configureSensors(){
max44009->init(config->getMAX44009_MODE());
bme280->init(config->getBME280_MODE());
mpu9250->init(config->getMPU9250_MODE());
// si1143->init(config->getSI1143_MODE());
gpsSensor->init(config->getuBlox_MODE());
When I run this I get two incorrect behaviors:
a) In the COM Window (serial to STLink Virtual COM Port) I see this upon startup…
The node does NOT join the network as evidenced by:
the message in above picture ‘Device is Not Activated’ (as well as the keys have not been generated
and
b) and the text is wrapped… (I am connected 9600)
![](https://www.thethingsnetwork.org/forum/uploads/default/original/2X/0/0281786fba3ecd78ed3864c3e53ff70a1b8f9264.png)
What do I have misconfigured…
Thank you for your assistance…
