In addition to @kersing: you do not only confuse others with a single channel gateway, but you would need to modify the set-up of your node(s) too to use exclusively use the channel/rate the gateway is providing.
Also the business case for single channel gateways has mostly gone; you can buy a fully LoRaWan compliant in-door plug in gateway for 60-70 Euro.
I am not sure where this idea of limitation came from. On the forum you find plenty of gateways of various brands described and commented. Just look at the Gateways category: https://www.thethingsnetwork.org/forum/c/gateways
And plenty listed in the documentation pages.
https://www.thethingsnetwork.org/docs/gateways/
OK, thanks to all for the more friendly responses
