LoRaWAN duty cycle abuse
Quite right, but that waht I’m talking about isn’t just trivial jamming.
I’m thinking about getting ten units. Street lights are Class C nodes, with ten transmitters I most probably can legally block their RX2 :slight_smile: Oh, I even don’t need GWs, ten half-Watt modules are enough… :slight_smile:
Poteto potato :nerd_face:.
Neither LoRaWAN nor TTN fair-use policy has any teeth here. They are both advisory. But the regional regulations about ISM band use are controlled, either by duty cycle or AFA/LBT. If someone breaks those rules then it is illegal and they are open to prosecution.
Like CE marking, its a complaint-driven process. If you complain enough, the local regulator should take action.
Start with googling for “lora preamble selectivity”, my dear electrical engineer and hobbyist. At the momement, LoRa seems to be double Dutch for you :slight_smile: Meditate, and you’ll reach you’ll reach enlightenment.
