MarcKCity:
what setting?
All the possible settings should be mentioned in the Readme.md file that accompanies the library.
However I will again point out that the relay program was designed for point to point LoRa, I cannot see how it could be used to make a proper TTN compliant relay …
MarcKCity
(Marc K City)
January 27, 2021, 2:48pm
43
Now i have a code made for getting data from arduino LoRa Node over the Relay to my heltec LoRa V2 Board but i need some help for the payload to mqtt
its about this : client.publish(“esp32/lora”, LoRaData);
how can i seperate the id / temp / humi ?
Here is my code:
#include <WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
#include <SPI.h>
#include <LoRa.h>
#include <U8x8lib.h>
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(/* clock=*/ 15, /* data=*/ 4, /* reset=*/ 16); // Oled
#define ss 18 // NSS Pin LoRa
#define rst 14 // Reset Pin LoRa
#define dio0 26 // dio0 Pin LoRa
const char* ssid = "xxxxxxxxxxxxxxx"; // Wlan SSID
const char* password = "xxxxxxxxxx"; // Wlan Passwort
const char* mqtt_server = "xxxxxxxxxx"; // MQTT Server IP Adresse
WiFiClient espClient;
PubSubClient client(espClient);
char msg[50];
void setup() {
Serial.begin(115200);
setup_wifi();
client.setServer(mqtt_server, 1883); // MQQT Port
client.setCallback(callback);
void setup_wifi() { // Setup Wifi
delay(10);
while (!Serial);
Serial.println("LoRa Empfänger");
LoRa.setPins(ss, rst, dio0); // LoRa Setup
while (!LoRa.begin(866E6)) { // Netzauswahl - Europa
Serial.println(".");
delay(500);
LoRa.setSpreadingFactor(7); // Spreading Faktor 7 - 12
LoRa.setSignalBandwidth(125E3); // Bandwidth zb. 125Kbaud - (125E3)
LoRa.setCodingRate4(5); // CodingRate 5 -
LoRa.enableCrc(); // Crc Check
LoRa.setSyncWord(0x34); // sync word ( 0-0xFF ) **** (0x34); für LoRaWan ****
LoRa.setFrequency(868100000); // Frequenz / Kanal
Serial.println("LoRa OK!");
u8x8.begin();
u8x8.setFont(u8x8_font_chroma48medium8_r);
u8x8.drawString(4, 0, "LoRa OK ");
Serial.println();
Serial.print("verbinden zu ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi verbunden");
Serial.println("IP Adresse: ");
Serial.println(WiFi.localIP());
u8x8.setCursor(2,1);
u8x8.print("IP Adresse");
u8x8.setCursor(0,2);
u8x8.print(WiFi.localIP());
delay(500);
void callback(char* topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Nachricht: ");
String messageTemp;
for (int i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
Serial.println();
void reconnect() {
while (!client.connected()) {
Serial.print("versuche MQTT zu verbinden...");
if (client.connect("ESP8266Client")) {
Serial.println("verbunden");
u8x8.setCursor(0,3);
u8x8.print("MQTT verbunden");
client.subscribe("esp32/output");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" erneuter Versuch in 6 Sekunden");
u8x8.print(" ");
u8x8.print("MQTT Fehler");
delay(6000);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
int packetSize = LoRa.parsePacket();
if (packetSize) {
Serial.println("empfangenes Packet '");
while (LoRa.available()) {
String LoRaData = LoRa.readString();
Serial.print(LoRaData);
u8x8.setCursor(0,4);
u8x8.print("Lora Packet:");
u8x8.setCursor(0,5);
u8x8.print(LoRaData);
client.publish("esp32/lora", LoRaData);
Serial.print("' mit der RSSI ");
Serial.println(LoRa.packetRssi());
u8x8.setCursor(0,7);
u8x8.print("RSSI: ");
u8x8.setCursor(6,7);
u8x8.print(LoRa.packetRssi());
descartes
(Nick McCloud)
January 27, 2021, 2:51pm
44
It’s good to hear you’ve got some sort of relay working.
This forum services topics on LoRaWAN on TTN and not general LoRa questions.
Maybe the Heltec forum could assist?
