I cannot get this code to work with a heltec wireless stick lite card, are other parameters necessary to modify?
I also copied the keyfiles file
; File: platformio.ini
; Function: Project configuration file for LMIC-node.
; Copyright: Copyright (c) 2021 Leonel Lopes Parente
; License: MIT License. See accompanying LICENSE file.
; Author: Leonel Lopes Parente
; Description: This is the main configuration file. It contains:
; - Board selector to select your board type
; - Common settings used for all boards
; - Board specific settings that can be altered per board.
; For a description of all settings see README.md
; | Board Selector |
; | Select your board by uncommenting EXACTLY ONE board-id below. |
[platformio]
default_envs =
; <platformio.ini board selector guard> Comment this line and uncomment one board-id below:
; LoRa development boards with integrated LoRa support:
; Board-id Board name
; adafruit_feather_m0_lora ; Adafruit Feather M0 LoRa
; disco_l072cz_lrwan1 ; Discovery B-L072Z-LRWAN1
; heltec_wifi_lora_32_v2 ; Heltec Wifi LoRa 32 V2
; heltec_wifi_lora_32 ; Heltec Wifi LoRa 32
heltec_wireless_stick_lite ; Heltec Wireless Stick Lite
; heltec_wireless_stick ; Heltec Wireless Stick
; lopy4 ; Pycom Lopy4
; lora32u4II ; BSFrance LoRa32u4 II v1.0, v1.1, v1.2, v1.3
; ttgo_lora32_v1 ; TTGO LoRa32 v1.3
; ttgo_lora32_v2 ; TTGO LoRa32 v2.0
; ttgo_lora32_v21 ; TTGO LoRa32 v2.1.6
; ttgo_t_beam ; TTGO T-Beam v0.5, v0.6, v0.7
; ttgo_t_beam_v1 ; TTGO T-Beam v1.0, v1.1
; Development boards that require an external SPI LoRa module:
; adafruit_qt_py_m0 ; Adafruit QT Py
; blackpill_f103c8_128k ; Black Pill 128k
; blackpill_f103c8 ; Black Pill 64k
; bluepill_f103c8_128k ; Blue Pill 128k
; bluepill_f103c8 ; Blue Pill 64k
; lolin_d32_pro ; Lolin D32 Pro
; lolin_d32 ; Lolin D32
; lolin32 ; Lolin32
; nodemcu_32s ; NodeMCU-32S
; nodemcuv2 ; NodeMCU V2
; pico ; Raspberry Pi Pico
; pro8mhzatmega328 ; Arduino Pro Mini 3.3V 8Mhz
; samd21_m0_mini ; SAMD21 M0-Mini
; teensylc ; Teensy LC
; | Common Settings |
; | These settings are shared by all board configurations except for |
; | nodemcuv2 which uses its own monitor_speed setting. |
[common]
monitor_speed = 115200 ; No need to change this.
build_flags =
-D DO_WORK_INTERVAL_SECONDS=60
; -D ABP_ACTIVATION ; Use ABP instead of OTAA activation.
; -D WAITFOR_SERIAL_SECONDS=10 ; Can be used to override the default value (10).
; Is used only for boards with default set to != 0 in BSF.
; -D LMIC_CLOCK_ERROR_PPM=0 ; If not defined defines, otherwise overrides value defined in BSF.
; Is for testing purposes only.
; Do not enable this unless you explicitly know what you are doing.
; -D STM32_POST_INITSERIAL_DELAY_MS=1500 ; Workaround for STM32 boards. Can be used
; to override value (milliseconds) in BSF.
lib_deps =
olikraus/U8g2 ; OLED display library
lnlp/EasyLed ; LED library
; ███ Add additional libraries for User Code below this line ███
; | Shortcuts to enable quick and easy changes |
[pico]
upload_port = E: ; For Raspberry Pi Pico.
; Operating system and hardware dependent.
; Placed here so it can be easily changed.
; See section [env:pico] below for more information.
; | MCCI LoRaWAN LMIC library specific settings |
[mcci_lmic]
; LMIC-node was tested with MCCI LoRaWAN LMIC library v3.3.0 and v4.0.0.
; Some changes have been announced for future versions of the MCCI library
; which may be incompatible with LMIC-node. In case of problems just
; use mcci-catena/MCCI LoRaWAN LMIC library@4.0.0 below which will
; explicitly use v4.0.0 of the library.
; Perform ‘PlatformIO: Clean’ after changing library version and
; in case of issues remove the old version from .pio/libdeps/*.
; Note: LMIC_PRINTF_TO is defined for each board separately
; in the board specific sections. Don’t define it in this section.
lib_deps =
; Only ONE of below LMIC libraries should be enabled.
mcci-catena/MCCI LoRaWAN LMIC library ; MCCI LMIC library (latest release)
; mcci-catena/MCCI LoRaWAN LMIC library@4.0.0 ; MCCI LMIC library v4.0.0
build_flags =
; Use platformio.ini for settings instead lmic_project_config.h.
-D ARDUINO_LMIC_PROJECT_CONFIG_H_SUPPRESS
; Ping and beacons not supported for class A, disable to save memory.
-D DISABLE_PING
-D DISABLE_BEACONS
; -D LMIC_DEBUG_LEVEL=1 ; 0, 1 or 2
; -D CFG_sx1272_radio=1 ; Use for SX1272 radio
-D CFG_sx1276_radio=1 ; Use for SX1276 radio
-D USE_ORIGINAL_AES ; Faster but larger, see docs
; -D LMIC_USE_INTERRUPTS ; Not tested or supported on many platforms
; -D LMIC_ENABLE_DeviceTimeReq=1 ; Network time support
; --- Regional settings -----
; Enable only one of the following regions:
; -D CFG_as923=1
; -D CFG_as923jp=1
; -D CFG_au915=1
; -D CFG_cn490=1 ; Not yet supported
; -D CFG_cn783=1 ; Not yet supported
; -D CFG_eu433=1 ; Not yet supported
-D CFG_eu868=1
; -D CFG_in866=1
; -D CFG_kr920=1
; -D CFG_us915=1
; | IBM LMIC framework library specific settings |
[classic_lmic]
; IMPORTANT:
; This library was recently DEPRECATED and is no longer maintained.
; It is not fully LoRaWAN compliant (e.g. in handling of MAC commands)
; and is therefore less suitable for use with The Things Network V3.
; Region, radio and debug settings CANNOT be changed in platformio.ini.
; They must be configured in file: config.h in the following location:
; .pio/libdeps//IBM LMIC framework/src/lmic
; When making changes to config.h:
; CONFIG.H MUST BE CHANGED FOR EACH BOARD SEPARATELY!
; (By default libraries are installed per project per build config/board.)
lib_deps =
matthijskooijman/IBM LMIC framework ; [Deprecated] Classic LMIC library
build_flags =
; DEFAULT VALUES defined in config.h:
; CFG_sx1276_radio 1
; CFG_eu868 1
; LMIC_DEBUG_LEVEL 0
-D DISABLE_PING
-D DISABLE_BEACONS
; | LoRa development boards with integrated LoRa support |
; | Some but not all of these boards have an onboard display. |
; | Some boards require additional wiring that needs to be manually added. |
; | Check the Board Support Files in the boards folder for information. |
