LMIC-node not connecting to TTN
Have you actually compiled and uploaded the code? Or are you still running the example the hardware was shipped with?
@descartes is MCCI LMIC configured to use the right US subband by default?
I have compiled and uploaded this LMIC-node code to the Heltec Wifi LoRa32(V2) board
Yes, it’s set in the LMIC-node.cpp based on the correctly setup region setting I can see in the quoted platformio.ini - the function call is LMIC_selectSubBand(1); and yes, it’s zero indexed.
Rather than a seeing a dozen or more repeated serial lines that don’t say much the first time, the log file with the settings shown plus just a couple of the EV_JOIN_TXCOMPLETEs.
I’ve lost track, has anyone asked for the gateway log for evidence of actual radio transmission?
Excellent. Are you sure your hardware is US915, not EU868 or even worse something 434MHz?
Can you please share?
As I can see your keys looks correct, your region is correct and you say you antennas are connected correctly. (We have recently seen a gateway connector broken. And that the antenna and gateway had the same connector, so it were not making contact).
Also are your gateway region and band set correctly?
I have no activity going on in either. and my gateway region is nam1 ( US) and US_902_928_FSB_1
Are you not suppose to use FSB_2?
As far a I understand LIMIC-node uses FSB_2
It does, it so very does. So the device is transmitting on FSB2 and the gateway is listening on FSB1 - no dice, no deal.
Thankfully you can just edit the entry for the gateway to the one that says FSB2 (used by TTN)
wow thank you guys so much, this fixed the issue, I knew it had to be simple, but I had no idea. Thank you so much again.
