Laird Sentrius RG1xx Firmware Update
I’ll be very interested in your results @jvbelle , I only have one and it’s my home (dev) gateway so I’m less inclined to experiment with it (I have enough yaks to shave as it is).
Good luck!
No luck over here. Its been a really bad experience using the Laird/TTN combo with basics station. First off, the upgrades/downgrades are really a pain to do correctly. Second, configuring the gateway is also not very convienent using the web config tool of the gateway. Logging is very limited in the UI.
I have tried the most recent tutorial from laird:
https://www.lairdconnect.com/documentation/application-note-setting-basics-station-ttn
But with no success. I cant get my Laird RG186 gateway connected to TTN by using basic station.
Does anybody have tips for me?
One concern of my: does ws port 443 go through my firewall?
That’s disappointing. You turned on the logging on the bottom bar, and dragged it open and said update automatically? The other logging is…terrible (the persistent logging with the same date/time is just annoying, is that fixed yet?)
Maybe paste a link to the log here (gist/pastebin)? I don’t think there’s anything secret in them, but have a look first :slight_smile:
From the log
RG1xx297A94 lora user.notice Jan 13 20:26:21 2021-01-13 20:26:21.583 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
RG1xx297A94 lora user.notice Jan 13 20:26:21 2021-01-13 20:26:21.582 [AIO:DEBU] [5] WS connection shutdown…
RG1xx297A94 lora user.notice Jan 13 20:26:21 2021-01-13 20:26:21.567 [AIO:XDEB] [5] ws_connecting state=1
RG1xx297A94 lora user.notice Jan 13 20:26:21 2021-01-13 20:26:21.540 [TCE:INFO] Connecting to INFOS: wss://lns.eu.thethings.network:443
RG1xx297A94 lora user.notice Jan 13 20:26:21 2021-01-13 20:26:21.539 [AIO:XDEB] [5] ws_connecting state=1
RG1xx297A94 lora user.notice Jan 13 20:26:21 key usage : Digital Signature, Key Cert Sign,
RG1xx297A94 lora user.notice Jan 13 20:26:21 basic constraints : CA=true, max_pathlen=0
RG1xx297A94 lora user.notice Jan 13 20:26:21 RSA key size : 2048 bits
RG1xx297A94 lora user.notice Jan 13 20:26:21 signed using : RSA with SHA-256
RG1xx297A94 lora user.notice Jan 13 20:26:21 expires on : 2021-03-17 16:40:46
RG1xx297A94 lora user.notice Jan 13 20:26:21 issued on : 2016-03-17 16:40:46
RG1xx297A94 lora user.notice Jan 13 20:26:21 subject name : C=US, O=Let’s Encrypt, CN=Let’s Encrypt Authority X3
RG1xx297A94 lora user.notice Jan 13 20:26:21 issuer name : O=Digital Signature Trust Co., CN=DST Root CA X3
That all looks fine, the right server from what we’re told, and you have a valid cert.
It’s probable the next messages will be the error/timeout. Also check if LoRa/Advanced has Logging Level set to Debug?
It keeps repeating this part over and over again (see bottom):
I cant find an option to set the Logging Level to Debug in the Gatway’s Web UI.
(I dont have remote logging, cant find a manual for that either so im using the logging from the web UI)
RG1xx297A94 lora user.notice Jan 14 08:22:24 2021-01-14 08:22:23.617 [TCE:INFO] INFOS reconnect backoff 60s (retry 8)
RG1xx297A94 lora user.notice Jan 14 08:22:24 2021-01-14 08:22:23.616 [AIO:DEBU] [3] WS connection shutdown…
RG1xx297A94 lora user.notice Jan 14 08:22:24 2021-01-14 08:22:23.608 [AIO:XDEB] [3] ws_connecting state=1
RG1xx297A94 lora user.notice Jan 14 08:22:24 2021-01-14 08:22:23.582 [TCE:INFO] Connecting to INFOS: wss://lns.eu.thethings.network:443
RG1xx297A94 lora user.notice Jan 14 08:22:24 2021-01-14 08:22:23.581 [AIO:XDEB] [3] ws_connecting state=1
What cert are you using?
Currently, their FW update URL is
https://connectivity-firmware.s3.amazonaws.com/rg1xx-lora-gateway/firmware/newest/fw.txt
