How to remove downlink_url from HTTP integration
You cannot delete/suppress it from within TTN. So, if Fiware does not allow you to do it, you need an intermediate server to change the JSON payload.
However, I think it’s weird that Fiware rejects this. For future readers, and to be sure you interpreted things correctly: where is that documented, or what error do you get?
Also, this makes me think that Fiware would be storing many more things than you’d need (like: all details from the JSON message). So, rather than deleting this one specific property you might better translate the full JSON to a much smaller message. That would still need an intermediate server though; Make TagoIO use timestamp from application payload instead of metadata might get you started. If you really want to delete specific properties, then in that Pipedream example use something like:
delete(body.downlink_url);
delete(body.payload_fields.event);
delete(body.payload_fields['temperature']);
delete(body['payload_fields']['battery']);
delete(body['metadata']);
const options = {
  url: targetUrl,
  data: body
Above, dot notation and bracket notation are interchangeable. But the latter might be required for property names that contain special characters; see Property Accessors.
