How to handle an automatic re-join process?
LoRaWAN confirmed uplinks probably don’t actually do what you want.
First, if you are using ADR (which is almost a given with OTAA) then the ADR state machine itself gives you some idea of confirmed connectivity.
Next, the confirmed message scheme is badly thought out - if you’re going to use it, then at least modify the node to never retransmit on failure, instead make the next ordinary message confirmed as well. That’s because if it’s the downlink side of the confirmation that fails, then no matter how many times you re-transmit the uplink, you will never get a confirmation for that re-used frame count.
But ultimately, what do you hope to accomplish in the case of failure - how is resetting the MCU going to fix anything?
