Do you recommend the MCCI library?
clavisound/SlimLoRa/blob/b2a2085ac23581cf9c69698f3245e7e71a2f7877/SlimLoRa.cpp#L89
- {0xE5, 0x59, 0xC0}, // Channel 4 917.400 MHz / 61.035 Hz = 15030720 = 0xE559C0
- {0xE5, 0x66, 0x8D}, // Channel 5 917.600 MHz / 61.035 Hz = 15033997 = 0xE5668D
- {0xE5, 0x73, 0x5A}, // Channel 6 917.800 MHz / 61.035 Hz = 15037274 = 0xE5735A
- {0xE5, 0x80, 0x27}, // Channel 7 918.000 MHz / 61.035 Hz = 15040551 = 0xE58027
- {0xE5, 0x8C, 0xF3}, // Channel 8 918.200 MHz / 61.035 Hz = 15043827 = 0xE58CF3
- {0xE5, 0x8C, 0xF3} // Downlink ??? MHz / 61.035 Hz = 15043827 = 0xE58CF3 // TODO 8 channels LoRa BW 500kHz, DR8 to DR13 starting at 923.300 MHz to 927.500 MHz, steps: 600KHz.
- #endif
- // BEELAN https://github.com/ElectronicCats/Beelan-LoRaWAN/blob/82da458bf8f98e8bf0e4c4eb5b7dd1b66787d2ba/src/arduino-rfm/RFM95.cpp#L38
- #ifdef US902 // page 21 line 435: 64 chanels starting 902.300 MHz to 914.900 MHz steps: 200KHz. DR0 (SF10) to DR3 (SF7) only!
- const uint8_t PROGMEM SlimLoRa::kFrequencyTable[9][3] = {
- {0xE1, 0xF9, 0xC0}, // Channel 0 903.900 MHz / 61.035 Hz = 14809536 = 0xE1F9C0
- {0xE2, 0x06, 0x8C}, // Channel 1 904.100 MHz / 61.035 Hz = 14812812 = 0xE2068C
- {0xE2, 0x13, 0x59}, // Channel 2 904.300 MHz / 61.035 Hz = 14816089 = 0xE21359
- {0xE2, 0x20, 0x26}, // Channel 3 904.500 MHz / 61.035 Hz = 14819366 = 0xE22026
- {0xE2, 0x2C, 0xF3}, // Channel 4 904.700 MHz / 61.035 Hz = 14822643 = 0xE22CF3
- {0xE2, 0x39, 0xC0}, // Channel 5 904.900 MHz / 61.035 Hz = 14825920 = 0xE239C0
- {0xE2, 0x46, 0x8C}, // Channel 6 905.100 MHz / 61.035 Hz = 14829196 = 0xE2468C
