This was actually more a reference to abstractions. You can make things much simpler by adding abstraction layers, but when something doesn’t work the abstractions most often won’t help and one needs to dive into the underlying complexities anyway.
“Known good solutions” are somewhat like (complexity hiding) abstraction layers.
If they don’t work as expected, finding the cause(s) often requires knowledge of the whole chain.
I was thinking of devices that don’t require any rocket-surgery to just get it started.
So, at best, AT command based that they can type through the commands to understand setting the Ids etc, getting a join, an uplink, a downlink and so forth. And see what happens at all points when you do things. And then link a simple MCU to run the commands automatically.
Certainly not a low-cost bodge of a me-too product that throws you straight to the community.
And definitely not a build your own or learning to compile for a feature-rich MCU. And I’d class a small Arduino (ie Uno/Nano/Pro Mini) with radio chip on SPI as a low-cost bodge for a beginner.
When using SPI LoRa, I wouldn’t advise anyone to start with 8-bit ‘Arduino’ (AVR) hardware these days (and especially not the 5V types) though. With 8-bit AVR + LMIC users will run into resource limitations very quickly (almost from the start).
I.m.o. there currently still doesn’t exist a best of bread generic LoRa development board suitable for beginners as well as advanced users. For less advanced (non-professional) users this usually should include Arduino framework support.
With generic I mean that it has sufficient available IO ports, is breadboard friendly, supports native 3.3V, supports LiPo / Li-ion or LiFePO4, optionally supports solar charging, and (very important) is low-power friendly (unlike many current popular LoRa boards that are not), is 32-bit, preferably ARM based.
The new Heltec CubeCell dev boards match many of above requirements and are also based on the newer SX1262 LoRa chip, but do not have much track record (yet). I also wonder if its architecture and implementation are open enough or that many details have been abstracted away (inaccessible) to make things simple for less advanced users. They also don’t support debugging via SWD or JTAG.
To be fair, that does sound a lot like the M0 Feather I was asked to use. The AdaFruit docs are pretty annoying, using a lot of exclamation marks and “see how easy this is!” language, and are probably a bit out of date in regards to which version of LMIC to use, and ignoring the rest of the world. But the board itself seems ok.
LMIC itself should be easy to use - you only need about 4 functions. But there are so many examples around with unnecessary code in them, and old messages saying what might fix your problems, etc that until you’ve spent a month with it and found all the cruft and figured out what you really need you do feel a bit adrift. I’ve not found any easy to understand explanation of things like the set link check mode (what does TTN does not supporting that actually mean? do I break something if I leave it enabled?) and setting the downlink window to rx2 for TTN - do I have to do those things or does the network tell the node about it when the node joins? I see those functions in examples but don’t know if I need to do it or not. And if so, when? After LMIC reset or after join?
The internet never forgetting is a big hassle here.
I feel for the MCCI maintainer. He’s (they’re?) doing a good job dragging the code into better shape but maintaining backwards compatibility is a stone around their neck. Eg, their downlink callback would be good to use in examples and application code, but I’ll bet no-one has yet. Making the various byte arrays default to the byte-ordering given in the TTN console by default would be a QoL improvement, and break the code against every other fork. Adding functions to get/set all the state necessary to sleep and wake up using a byte array would be nice and probably not even break compatibility for once.
But you’re still at the mercy of the gateway. And if you need your own gateway and a logic analyzer to have a fighting chance at diagnosing problems then the protocol is not ready for mainstream adoption. I do have a logic analyzer, I just didn’t expect I’d need it for something as trivial as this project.
That’s not to say it isn’t perfectly good for a company who control the entire stack from node to server and deploy their own gateways. Which my sponsor is (mostly) doing. They’re using TTN but do control their gateways. I’m just sure I have a dodgy one
I suspect that’s an incorrect analysis of the situation.
There’s very little for a gateway owner to “control” that matters in a protocol sense. Mostly what ownership gets you is the ability to monitor what is happening for debug understanding.
And no, it’s not particularly likely that you have a flaky gateway. Possible, but much less likely that node-side issues.
This is the classic example of the abstraction problem - everything is abstracted, which can be great if it works, but if it doesn’t work it’s pretty much impossible to understand why or fix it.
And most of the products that did that had serious flaws in their initial versions - power issues, issues with regional modes the developers didn’t really understand, etc. Some of them have fixed some of these problems, others haven’t.
In the better cases the AT command set firmware is open, debuggable, and repairable.
The project sponsor brought me a different GW to test with today and it’s going much better. This is a Laird RG-191 Sentrium.
The new GW is connected to my home office WiFi AP, which is wired to my home router/vDSL modem so the path is:
GW --> WiFi --> AP --> ethernet cable --> router/modem --> copper wires to pillar --> vDSL mux…
The occasional downlink is still being missed, but the missed ones come through in far less attempts than was usual with the other GW. When I have more time I’ll connect the GW to the AP with an ethernet cable rather than WiFi and see if that improves matters. I didn’t do that today because I’ll have to take my laptop/feather further away to keep some distance between the GW and the feather and I didn’t have time to work around that this morning.
This is all still within a double garage, so I’ll also try it outside with a lot more distance between the GW and feather. That didn’t make any difference with the old GW, I’d tried it a couple of times.
The sponsor also had an idea for why I had 3 good tests and 1 bad on-site. When I told him where I’d parked for the bad test he thought it made sense because I would have had a much worse LoS to the GW than for the 3 good ones.
Hey guys, I have a question regarding the use of downlinks. Is there any way for my RAK11721 module to read a downlink from TTN and send it back to me in my microcontroller? To be more specific, I have a code in micropython and I’m using AT commands to connect with TTN, I want to know if anyone knows an AT command that can read a downlink when it shows up in TTN to send it back to my microcontroller because I’ve already read the datasheet of RAK11721 and couldn’t find it.
