Do you see join attempts in the gateway traffic?
Just wondering about the correct sub band also
keys are just msb format
When adding a device in TTN console (and in its properties) you can switch keys between msb and lsb format and then copy and paste them in source code.
Like @Paul_Stewart said CubeCell uses msb (most significant byte first) format for all keys and ID’s.
This is different from the LMIC library which requires part of them in lsb format and the others in msb format. If you are used to using the LMIC libray, you need to be aware that CubeCell uses msb format only. It’s easy to overlook and when the keys are in incorrect byte order in your source code, it won’t connect to TTN.
I’ve just received my CubeCell (HTCC-AB02) and tested the PlatformIO LowPower example and the LoraWan example and measured the power consumption with a Ruideng on the usb port. With both examples in deep sleep I got about 8 mAH power consumption but as I read the chip should only consume 9.6 uA in deep sleep with usb. What do I have to do to get the chip down to 9.6 uA?
Don’t connect USB.
I’ve just applied 3.3 volts directly to the VIN pin, but the power consumption is still 8 mAH in deep sleep and about 20 mAH when the device is awake. I used the LowPower example. Do I maybe also need to comment out the Serial port lines in the example?
How do you measure current?
And some posts further below for current usage with LiPo connected.
I measured using a multimeter and my lab powersupply. Both show the same value. I also tried disabling the AT commands and disabling Vext via digitalWrite(Vext, HIGH) but that didn’t change anything.
Hello, what do you mean with the sub band? and that the keys are in msb format? I don’t really know anything about it. I took the sketch of the LoRaWAN example offered by Arduino IDE, just change the code keys for the keys that TTN gave me, configure the parameters of the CubeCell HTCC AB-01 module and that’s it. The frequency band of the module and the Gateway is the same (US915). Could you please be more explicit about what I should do, review and modify?
Hello, I am not using that library. I took the LoRaWAN sample sketch offered by Arduino IDE and modified the keys (I left the keys that TTN gave me). The code only comes with these 2 included libraries:
#include “LoRaWan_APP.h”
#include “Arduino.h”
I uploaded some screenshots and the code in .txt file as support.
@bluejedi Something strange just happened. After I connected the device to the lab power supply I attached it again to usb. Immediately after plugging in I saw smoke coming from the device. I unplugged it and plugged it in again. Everything still seems to work, but the device no consumes 2 mAH more in deep sleep. Any idea what just happened?
Edit: I found out what I did wrong. I connected the lap power supply to VIN instead of VDD. I hope I did not damage the board.
OK, I checked out US915 and sub band shouldn’t be an issue.
Let’s just try and step through a few basics to rule stuff in or out.
Try this stuff and post back some results
Hello, check the antennas of both the Gateway and the module and they are well connected. I still don’t see data traffic on the TTN console of the Gateway. I attach the requested screenshots. Thank you very much for your help.
Hello, I was missing telling you that the Gateway UG87 is less than 2m away from the CubeCell HTCC AB-01 module. I also did the test with the other two CubeCell HTCC AB-01 modules that I have but still can’t get the connection, so it’s not a problem of a specific module, it must be wrong module or gateway configuration maybe.
I don’t use ABP much but I’m trying to work out why you have three different ones - sketch, serial monitor and TTN.
Have you tried OTAA? (just re-check your app key if you change back to OTAA)
Can you also show us your radio channels settings in the gateway please
Hi, I did the test with OTAA but still can’t get it.
She means “I’m trying to work out why you have three different ones - sketch, serial monitor and TTN”.
I attach the requested screenshots. Thank you.
OK, looks like you are using sub band 1 - you can see your TX frequencies are below where your first gateway channel starts.
You need sub band 2 to be set by your channel mask in your sketch
/*LoraWan channelsmask, default channels 0-7 - 0xFF00 sets to sub band 2 */
uint16_t userChannelsMask[6]={ 0xFF00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000};
Hello, thank you very much for your help. I did what you told me, I modified the channel mask (from 0x00FF to 0XFF00) and it worked perfectly. I can already see data traffic on the TTN console of the gateway and the device. Thanks to that I can move forward. Now if it’s not annoyance, I have more questions for you:
Any information you can offer me will be of great help. Thank you again.
