Gateway status connected but enable to receive data from lora end node
Fix your configuration, fake gps coordinates should not be at 0,0.
Also add some information to your message, don’t expect us to guess what is and what isn’t happening. Good starting point would be to answer the next questions:
  • What frequency plan are you using?
  • What is your hardware?
  • Where in the world are you located?
  • Why do you expect to receive data? (Is there a known working node sending packets?)
And finally, learn to format your postings properly.
