Gateway IMST IC880A / RBPI
Just a quick note - I have just released the passive PoE enabled ic880a to RPI connection board here: https://www.tindie.com/products/marcel/ic880a-lorawan-poe-adapter-for-raspberry-pi
This means its really simple and almost cable free to connect the ic880a to the RPI
If you are a TTN network member in any capacity please use the ‘ttnrulez’ for voucher you get 10% off the order.
is that (high) prize for 1 assembled and tested board?
Yes, that is fully populated and tested board.
Hi there,
My gateway (iC880a+RPi3) is up and running and I have a node with RN2483 connected to a current sensor transmitting data correctly(radio_tx_ok). How do I check if this is being received by my gateway? How do I get this data to TTN? Please help
Have you solved this now?
Yes I got it sorted @dicktonyboy. Thanks a lot. I am a core member of TTN here in Kenya, I would really like us to have a TTN workshop down here in Kenya. The first in Africa. Any set of people interested in something like this. Check out my profile on LinkedIn.
I’d really like to say “I’m on my way!”
