It sounds like they’re using SF12 out of laziness, not out of need.
Is it even using TTN?
Once badly coded nodes are in the field, they’re probably not going to change behavior.
Yes it is using TTN.
It was commissioned by Fleet Space on behalf of the local councils and SA Water. I am aware of the person (on Slack) who coded the 200-300 nodes.
I will ask why they are running on SF12 but very occasionally I see one running on SF10, so I suspect they may be running ADR. However my gateways reply quite a few times so I suspect the nodes are running in Confirmed mode.
Thanks Tony, probably best if we continue this conversation back in High quantity of SF12 Uplink Messages if needed as not to hijack the thread.
Just imagining, since TTN NS monitors, it would be cool to have an indicator in the console to see if your node is complying. Console background red? Then you’re outside the FUP !
