Ok, since the gateway works fine with the Dagino LHT65 under the RX2/SF9 plan this should be a sign that the gateway’s antenna is fine.
I don’t know how popular these Browan IAQ devices are.
Besides hardware defects of the device, could the device be shipped with a buggy firmware that simply isn’t prepared to deal with the RX2/SF12 variant?
frequency plan set to RX2/SF12, placed at old location (few meters + brick wall) and triggered an OTAA join → result: no measurements are received after the initial data messages; blue led blinks 7 times (short), followed by 2 double blinks (i.e. after inserting the battery)
frequency plan set to RX2/SF9, placed at second location (also few meters + a brick wall) and triggered another OTAA join → result: measurements are received every 5 minutes; blue led
blinks 7 times (short) followed by 3 double blinks (i.e. after inserting the battery)
That means that the frequency plan variant doesn’t make a difference, but the initial location of the OTAA join is crucial. After the join is completed, the location doesn’t matter anymore.
PS: FWIW, Browan hasn’t processed my account request for days. Thus, I can’t access the TBHV110 reference manual on their site. However, I found a copy at https://docs.microshare.io/assets/pdf/TBHV110.pdf It contains some details, but isn’t comprehensive. Especially, it doesn’t describe the LED blink codes, at all.
PPS: After removing the battery the last time I shorted the +/- contacts using a small resistor in order to empty any built-in capacitor. Before inserting the battery again I measured the voltage as 2.65 V (instead of the previous 3.6 V). The drop was sufficient for the OTAA join to be initiated. Previously, I just let the device sit for a few hours without the battery inserted. Again, the reference manual doesn’t mention anything about how the device is supposed to be reset, how the OTAA join can be initiated, etc.
It’s possible that it’s a coincidence since the number of observations is low:
2 to 3 meters from gateway without a brick wall: 2 out of 2 times no sensor readings after each join attempt → always failed so far
old location, i.e. 5m or so behind a brick wall: 2 out of 2 times no sensor readings after each join attempt → always failed so far
new location, i.e. 5m or so behind another brick wall: 2 out of 2 times sensor readings are transmitted at a 5 minute interval after each join attempt → always succeeded so far
After a successful join I receive sensor readings everywhere at a 5 minute interval. Even when I place the device 2 m away from the gateway without a brick wall in between!
All I can tell you - If you have the node and the gateway that close, the RF is shouting at each other, sooner or later you are going to damaged one of the receivers.
You can’t go to the club and stand next to the bands speakers, sooner or late you are going to lose your hearing.
Yes 5m and brick wall, just check the RSSI as well, you need rssi as low as you can get.
Remember you are going to deploy your nodes typically a few 100m or km away so you can expect a significant drop in rssi and snr, which is where you want to test.
For the gateway, both Europe 863 MHz frequency plan variants SF12 for RX2 and SF9 for RX2 are equivalent. A future version of the UI might replace both options with a single entry to avoid confusion, when configuring a gateway.
it’s very unlikely that OTAA devices can’t deal with the recommended SF9 for RX2 frequency plan variant
likely causes for an OTAA device not completing a join/proper transmission is a) device is too far away from a gateway (obvious, i.e. signal quality insufficient) or b) device is too close to a gateway (less obvious, i.e. receiver overload)
if a device is too close to its gateway the receiver overload doesn’t have to be symmetric, leading to asymmetric failures (e.g. join fails, but later sensor transmissions succeed)
Resetting the Browan TBHV110 IAQ to trigger a fresh OTAA join is quite involved since it buffers electric energy, i.e. there is no reset button and thus the battery has to be removed for 6h or so for the internal buffer to be discharged enough
the example data in the TTN device repository doesn’t necessarily contain realistic timestamps, cf. online airtime calculator
Thanks to everyone who participated in this thread. My questions were answered and I learned a lot.
