Allthough gateway made by joining a Dragino shield and a Raspberry Pi is not considered acceptable for TTN, is it possible to join to the TTN net for testing purposes? Is there some mechanism that lock such a setup?..I succeeded yesterday to put this setup into service (since my other approach using a Lopy as nanogateway following Pycom indications did not work), and initially was accepted but it did not appear in my console as one of my gateways. In fact, sensor values reached the network and values were showned. The gateway was working correctly for hours…However, today I cannot let it work…some comment regarding this behaviour?
Hi.
Only I teach programming and Lora. I Have RPI3+Lora\GPS hat for my gateway, code https://github.com/tftelkamp/single_chan_pkt_fwd. Please tell me where in the code to output the information that I sent to the file, not uploading to the server.
Hi ! My friends! Currently I am receiving " Hello World" message. However, I would like to connect the DS18B20 with the Lora shield v1.4, I tried and no success! I need to know which ports are available to connect the data pin of the sensor? Red >> 5V, Black >> Ground and I guess white is the data pin …
I downloaded a different code and got it working on the rpi/hat. This one does poll the server. I was only able to get 3 packets sent in the downlink. Haven’t been able to recreate it since.
I did by commenting die() too. Changing the pin config didn’t make a difference coz when I commented die() I got it working. Also I was able to get downlinks but only a few (till now 3). Have you got regular downlinks on your device? Also is there any way we can check if the nodes receive the downlinks?
Hi everyone! Im new to LoRa technology. Im about to make a gateway using my Dragino 433MHz LoRa/GPS Hat and RPi 3B. I have read several tutorials including dragino wiki but they use the frequency either 915MHz and 868MHz connecting to TTN. And based on my research, 433MHz is not compatible with LoRaWAN TTN. Can someone please help me how to configure my gateway without connecting it to TTN? A big thank you in advance!
Hi All. Trying to use the dual_chan_pkt_fwd with an InAir9b but my radio isn’t being recognised.
with:
“pin_nss”: 6,
“pin_dio0”: 7,
“pin_nss_2”: 6,
“pin_dio0_2”: 7,
“pin_rst”: 0
in the global.conf.json file, despite these being the correct connections to the RPi.
However it is recognised when using single_chan_pkt_fwd with:
int ssPin = 6;
int dio0 = 7;
int RST = 0;
in main.cpp
These should surely be equivalent, so no idea what the problem could be.
Any ideas would be appreciated. Cheers Ron
I’m trying to set up a Dragino LG01-S LoRa Gateway but have run into a problem.
It’s working fine but I would like to run a VPN client on the Dragino and create a connection back to my own VPN server.
I’m halfway there and can get the Dragino to connect to my VPN but it becomes inaccessible once connected and only stays connected for around 60 seconds. It does not respond to pings from the VPN server.
I guess that I am missing a firewall rule somewhere but, as I can’t connect to the Dragino once it is connected to the VPN, I can’t work out where/what the rule needs to be!
My VPN config creates an interface called tun0 so I have created a new interface called “vpn” in /etc/config/network and assigned tun0 to it. I’ve also added the vpn interface to the existing firewall WAN rule.
Has anyone managed to get a VPN working on the Dragino or does anyone have any experience getting a VPN client working on OpenWRT?
