The only additional unused device i have is exactly the same node (Dragino LDDS75).
You mean i should check if this device has the same problems?
I have a few other nodes which are working just fine. also Dragino devices.
I tried with a brand new out of the box sensor and it works perfectly fine.
As far as i can tell.
So the problem is on the node sideā¦
Iād call that broken and return it to the seller.
