Downlink seems to not work
The V3 backend seems to think your gateway is offline and can be used for a downlink. This is not node related.
What is the keepalive_interval of your gateway set to?
This points to incorrect AppKey. Check you didn’t mix up characters. You would not be the first to use 8 where B should be used or vice versa.
PS, next post please format large text dumps for readability.
