hi @cslorabox, I hope you are not tired of me, and can help-me ![:grin: :grin:](https://www.thethingsnetwork.org/forum/images/emoji/apple/grin.png?v=9)
I am using the ABP and OTTA example from the MCCI library, in the examples already have this configuration. I also checked before writing the first time, too
I also tried to disable link check validation before and after “case EV_JOINED” , but it did not work
LMIC_setLinkCheckMode(0);
I pointed again to the TTN, to have more access to the logs, every uplink , i get a downlink. You can see the pictures ? Thanks
https://ibb.co/8D2Wzyw // device
https://ibb.co/mhrmn0W // device
https://ibb.co/5hGqTVR // gateway
https://ibb.co/4Z5tYXQ // gateway
Below, a log of downlink on gateway Dragino-LG02
(RXPKT): [up] {“rxpk”:[{“time”:“2020-07-01T21:15:14.855718Z”,“tmst”:3384576861,“chan”:0,“rfch”:1,“freq”:915.200000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:7.8,“rssi”:-57,“size”:26,“data”:“QFoWASaALQABy6gPr2g90WGCZw+5jXlHBWE=”}]}
(TXPKT): [down] {“txpk”:{“imme”:false,“tmst”:3386576861,“freq”:923.3,“rfch”:0,“powe”:20,“modu”:“LORA”,“datr”:“SF12BW500”,“codr”:“4/5”,“ipol”:true,“size”:22,“ncrc”:true,“data”:“YFoWASaKJgADQAIAcQM1AP8Bihrl3g==”}}
Receive(HEX):405a160126802e00013db6e37aea0c26c2e347887ff16dd767b7
