Here is the code ported to the IoTFactory Platform.
Under Device Types->Config you require a JS code to parse the payload from an MQTT Server to the internal IoTFactory Format (JSON).
THanks to Stephane Demingongo from IoTFactory for such adaptation, here is the code working:
* Byte stream to fixed-point decimal word.
* @param stream: array of bytes.
* @return: word of the bytes in big-endian format.
function arrayToDecimal(stream, is_signed = false, decimal_point = 0) {
var value = 0;
for (var i = 0; i < stream.length; i++) {
if (stream[i] > 0xff) throw "Byte value overflow!";
value = (value << 8) | stream[i];
if (is_signed) {
edge = 1 << (stream.length * 8); // 0x1000..
max = (edge - 1) >> 1; // 0x0FFF.. >> 1
value = value > max ? value - edge : value;
if (decimal_point) {
value /= Math.pow(10, decimal_point);
return value;
* Cayenne Low-power Payload Decoder
* @param {string} payload hexadecimal.
* @return: JSON
function decode(payload) {
payload = String.prototype.match.apply(payload, [/.{1,2}/g]);
payload = payload.map(function(hex) {
return parseInt(hex, 16);
* @reference https://github.com/myDevicesIoT/cayenne-docs/blob/master/docs/LORA.md
* Type IPSO LPP Hex Data Size Data Resolution per bit
* Digital Input 3200 0 0 1 1
* Digital Output 3201 1 1 1 1
* Analog Input 3202 2 2 2 0.01 Signed
* Analog Output 3203 3 3 2 0.01 Signed
* Illuminance Sensor 3301 101 65 2 1 Lux Unsigned MSB
* Presence Sensor 3302 102 66 1 1
* Temperature Sensor 3303 103 67 2 0.1 °C Signed MSB
* Humidity Sensor 3304 104 68 1 0.5 % Unsigned
* Accelerometer 3313 113 71 6 0.001 G Signed MSB per axis
* Barometer 3315 115 73 2 0.1 hPa Unsigned MSB
* Gyrometer 3334 134 86 6 0.01 °/s Signed MSB per axis
* GPS Location 3336 136 88 9 Latitude : 0.0001 ° Signed MSB
* Longitude : 0.0001 ° Signed MSB
* Altitude : 0.01 meter Signed MSB
var sensor_types = {
0: { size: 1, name: "Digital Input", signed: false, decimal_point: 0 },
1: { size: 1, name: "Digital Output", signed: false, decimal_point: 0 },
2: { size: 2, name: "Analog Input", signed: true, decimal_point: 2 },
3: { size: 2, name: "Analog Output", signed: true, decimal_point: 2 },
101: {
signed: false,
decimal_point: 0
102: { size: 1, name: "Presence Sensor", signed: false, decimal_point: 0 },
103: {
signed: true,
decimal_point: 1,
unit: "°C"
104: { size: 1, name: "humidity", signed: false, decimal_point: 1, unit: '%' },
113: { size: 6, name: "accelerometer", signed: true, decimal_point: 3 },
115: { size: 2, name: "barometer", signed: false, decimal_point: 1 },
134: { size: 6, name: "gyrometer", signed: true, decimal_point: 2 },
136: {
signed: false,
decimal_point: [4, 4, 2]
var sensors = [];
var i = 0;
while (i < payload.length) {
s_no = payload[i++];
s_type = payload[i++];
if (typeof sensor_types[s_type] == "undefined") {
console.error("Sensor type error!: {}", s_type);
break;
s_size = sensor_types[s_type].size;
s_name = sensor_types[s_type].name;
s_id = sensor_types[s_type].id;
s_unit = sensor_types[s_type].unit;
switch (s_type) {
case 0: // Digital Input
case 1: // Digital Output
case 2: // Analog Input
case 3: // Analog Output
case 101: // Illuminance Sensor
case 102: // Presence Sensor
case 103: // Temperature Sensor
case 104: // Humidity Sensor
case 113: // Accelerometer
case 115: // Barometer
case 134: // Gyrometer
s_value = arrayToDecimal(
payload.slice(i, i + s_size),
(is_signed = sensor_types[s_type].signed),
(decimal_point = sensor_types[s_type].decimal_point)
break;
case 136: // GPS Location
s_value = {
latitude: arrayToDecimal(
payload.slice(i + 0, i + 3),
(decimal_point = sensor_types[s_type].decimal_point[0])
longitude: arrayToDecimal(
payload.slice(i + 3, i + 6),
(decimal_point = sensor_types[s_type].decimal_point[1])
altitude: arrayToDecimal(
payload.slice(i + 6, i + 9),
(decimal_point = sensor_types[s_type].decimal_point[2])
break;
let s = {
type: s_name,
value: s_value,
if (s_id) {
s.id = s_id;
} else {
s.id = 'sensor ' + s_no;
if (s_unit) {
s.unit = s_unit;
sensors.push(s);
i += s_size;
return sensors;
return decode(payload);
