Couple of questions after setting up my gateway
I’m not sure if the OP has a GPS-enabled gateway too? If not, then it should not send coordinates from some configuration file (nor send any time), but instead use TTN Console; see Gateway GPS configuration in local_conf.json - #4 by htdvisser.
