As you will no doubt be aware from following the tutorial to create the gateway, you have a Single Channel Packet Forwarder which is disruptive to the network and are not suitable or welcome for connection to TTN.
And that is the reason your MKR WAN won’t / can’t / could one day connect - it is using 8 channels and you have only one.
Please disconnect it immediately. You can read more here:
