I have re-installed the image of the SD card with loriot.
Iâm not expert with the loriot stuff but I feel the concentrator is working . Am I right ?
The deamon.log seems to show a working concentrator does it ?
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: *** Lora concentrator HAL library version info ***
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: Version: 4.1.0;
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Little endian host
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: found global configuration file global_conf.json, parsing it
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: lorawan_public 1, clksrc 1
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: LBT is disabled
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: antenna_gain 0 dBi
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Configuring TX LUT with 16 indexes
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 129000
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: gateway MAC address is configured to AA555A0000000000
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: server hostname or IP address is configured to âiot.semtech.comâ
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: upstream port is configured to â1680â
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: downstream port is configured to â1680â
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: downstream keep-alive interval is configured to 10 seconds
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: statistics display interval is configured to 30 seconds
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: packets received with a valid CRC will be forwarded
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: packets received with a CRC error will NOT be forwarded
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: packets received with no CRC will NOT be forwarded
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: found local configuration file local_conf.json, parsing it
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: redefined parameters will overwrite global parameters
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: local_conf.json does not contain a JSON object named SX1301_conf
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: gateway MAC address is configured to B827EBFFFE84F259
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: [main] concentrator started, packet can now be received
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Disabling GPS mode for concentratorâs counterâŠ
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: host/sx1301 time offset=(1490120240s:313614”s) - drift=-1483164402”s
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: Enabling GPS mode for concentratorâs counter.
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 62 ms
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 63 ms
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 61 ms
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:11:56 GMT #####
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ### [UPSTREAM] ###
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 0
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # RF packets forwarded: 0 (0 bytes)
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA acknowledged: 0.00%
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ### [DOWNSTREAM] ###
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # TX errors: 0
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # BEACON queued: 0
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # BEACON sent so far: 0
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ##### END #####
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:11:56 GMTâ,ârxnbâ:0,ârxokâ:0,ârxfwâ:0,âackrâ:0.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 63 ms
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 83 ms
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:12:26 GMT #####
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 1
Mar 21 19:12:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Mar 21 19:12:52 LoRaGateway systemd[1]: loriot.service start operation timed out. Terminating.
Mar 21 19:12:52 LoRaGateway systemd[1]: Failed to start loriot LoRaWAN client.
Mar 21 19:12:52 LoRaGateway systemd[1]: Unit loriot.service entered failed state.
Mar 21 19:12:52 LoRaGateway systemd[1]: Starting Multi-User System.
Mar 21 19:12:52 LoRaGateway systemd[1]: Reached target Multi-User System.
Mar 21 19:12:52 LoRaGateway systemd[1]: Starting Graphical Interface.
Mar 21 19:12:52 LoRaGateway systemd[1]: Reached target Graphical Interface.
Mar 21 19:12:52 LoRaGateway systemd[1]: Starting Update UTMP about System Runlevel ChangesâŠ
Mar 21 19:12:52 LoRaGateway systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 21 19:12:52 LoRaGateway systemd[1]: Startup finished in 3.857s (kernel) + 1min 49.724s (userspace) = 1min 53.582s.
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # RF packets forwarded: 0 (0 bytes)
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 1 (111 bytes)
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA acknowledged: 100.00%
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ### [DOWNSTREAM] ###
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # TX errors: 0
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # BEACON queued: 0
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # BEACON sent so far: 0
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ##### END #####
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: Disabling GPS mode for concentratorâs counterâŠ
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: host/sx1301 time offset=(1490123484s:215130”s) - drift=-1051065780”s
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: Enabling GPS mode for concentratorâs counter.
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:12:26 GMTâ,ârxnbâ:1,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 63 ms
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 62 ms
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:12:56 GMT #####
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ### [UPSTREAM] ###
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 0
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 1 (113 bytes)
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:12:56 GMTâ,ârxnbâ:0,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 64 ms
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 61 ms
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:13:26 GMT #####
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 1
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: host/sx1301 time offset=(1490123484s:215604”s) - drift=474”s
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:13:26 GMTâ,ârxnbâ:1,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 265 ms
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 204 ms
Mar 21 19:14:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:13:56 GMT #####
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # BEACON sent so far: 0
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: ##### END #####
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:13:56 GMTâ,ârxnbâ:0,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 62 ms
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 62 ms
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 181 ms
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:14:26 GMT #####
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: ### [UPSTREAM] ###
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 0
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # RF packets forwarded: 0 (0 bytes)
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 1 (113 bytes)
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA acknowledged: 100.00%
Mar 21 19:14:27 LoRaGateway lora_pkt_fwd[630]: ### [DOWNSTREAM] ###
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # TX errors: 0
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # BEACON queued: 0
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # BEACON sent so far: 0
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ##### END #####
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: Disabling GPS mode for concentratorâs counterâŠ
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: host/sx1301 time offset=(1490123484s:216071”s) - drift=467”s
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: Enabling GPS mode for concentratorâs counter.
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:14:26 GMTâ,ârxnbâ:0,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 63 ms
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 60 ms
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 70 ms
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 61 ms
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:14:56 GMT #####
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ### [UPSTREAM] ###
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 1
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # RF packets forwarded: 0 (0 bytes)
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 1 (113 bytes)
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA acknowledged: 100.00%
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ### [DOWNSTREAM] ###
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:14:56 GMTâ,ârxnbâ:1,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 62 ms
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:15:26 GMT #####
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 0
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: host/sx1301 time offset=(1490123484s:216535”s) - drift=464”s
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:15:26 GMTâ,ârxnbâ:0,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 62 ms
Mar 21 19:16:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:15:56 GMT #####
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # BEACON sent so far: 0
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: ##### END #####
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:15:56 GMTâ,ârxnbâ:1,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 63 ms
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 62 ms
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 61 ms
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:16:26 GMT #####
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: ### [UPSTREAM] ###
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 0
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # RF packets forwarded: 0 (0 bytes)
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 1 (113 bytes)
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA acknowledged: 100.00%
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: ### [DOWNSTREAM] ###
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 21 19:16:27 LoRaGateway lora_pkt_fwd[630]: # TX errors: 0
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # BEACON queued: 0
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # BEACON sent so far: 0
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: ##### END #####
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: INFO: Disabling GPS mode for concentratorâs counterâŠ
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: INFO: host/sx1301 time offset=(1490123484s:216985”s) - drift=450”s
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: INFO: Enabling GPS mode for concentratorâs counter.
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: JSON up: {âstatâ:{âtimeâ:â2017-03-21 19:16:26 GMTâ,ârxnbâ:0,ârxokâ:0,ârxfwâ:0,âackrâ:100.0,âdwnbâ:0,âtxnbâ:0}}
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: INFO: [up] PUSH_ACK received in 63 ms
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 61 ms
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: INFO: [down] PULL_ACK received in 62 ms
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: ##### 2017-03-21 19:16:56 GMT #####
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: ### [UPSTREAM] ###
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # RF packets received by concentrator: 0
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # RF packets forwarded: 0 (0 bytes)
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA datagrams sent: 1 (113 bytes)
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # PUSH_DATA acknowledged: 100.00%
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: ### [DOWNSTREAM] ###
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 21 19:18:26 LoRaGateway lora_pkt_fwd[630]: # TX errors: 0
Mar 21 19:18:27 LoRaGateway lora_pkt_fwd[630]: # BEACON rejected: 0
Mar 21 19:18:27 LoRaGateway lora_pkt_fwd[630]: ### [JIT] ###
Mar 21 19:18:27 LoRaGateway lora_pkt_fwd[630]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 21 19:18:27 LoRaGateway lora_pkt_fwd[630]: ### [GPS] ###
Mar 21 19:18:27 LoRaGateway lora_pkt_fwd[630]: # GPS sync is disabled
