CFList is not contained in Join Accept Packet
If I recall correctly the channel list is passed as response to the first uplink for channel plans other then Eu868. I’m referring to
Perhaps you need to take a look at the regional parameters to see if the same issue applies to AS915 and at the code to see if TTN uses the same mechanism.
