Capture and analyze LoRa packets
Maybe a stupid question, but will this also mean you can use dumpcap and then use tshark to extract stuff from the packets?
I have written a spec to encapsulate LoRa packets (https://github.com/eriknl/LoRaTap), I have some PoC hardware with a sx1272 that captures the raw data to pcap which can then be analyzed in Wireshark. Lack of time kept me from releasingā€¦
Yes, any part of Wireshark using the dissector can do so. But the dissector has to be set up to be ā€˜compatibleā€™ with ethernet link layer captures before can recognize LoRaWAN packets on ethernet.
Just in case parsing some hexadecimal or Base64 string from some log is easier, the following Node.js/JavaScript library can decipher the non-encrypted parts:
