we’ve deployed the TTS Open Source version 3.13.3. If we try to connect via MQTT over the port 1883, it works like a charm. But, if we try to do the same over the port 8883. We’re stuck and we don’t know what to do to solve the problem. We’re aware that this is very generic but we don’t know what to loop up.
Thanks in advance. Any help to point us where to look up will be really appreciated.
@JTrigo
When asking for help on the forum and getting response from other users with solutions/suggestions but not let hear from you again (whatsoever) is disrespectful.
This is not how it works on the forum and does not motivate users to invest their time in helping others a next time.
Unless this is all within a closed firewalled network, or over a VPN, you really don’t want to do that.
MQTT sends access credentials in cleartext, so in the real world you need to be using the MQTT-over-SSL port 8883, which means you need to figure out the certficate / chain / validation or even clock issues that are preventing that from working.
@cslorabox thank you very much for the advice. We are testing it but we have already taken into account all those details that you have mentioned. The next thing we want to achieve is using port 8883, but first, we need to learn how to configure and resolve all the issues with certificates/chains etc.
