Caused me all sorts of drama this. Need to be a good distance away! See all kinds of weirdness
how can i post my question on this Forum. Trying for last 5 hours but no way. Thank you
If you start with a factory fresh MultiTech gateway and only run the installer you will have only one packet forwarder running, the mp_pkt_fwd. If after installation you used the wizard to configure LoRaWAN settings might change things in a way that make two packet forwarders run. If that is the case you could run the installer again and hopefully that resolves the issue.
Ok, nice. I will fresh the GW and test it.
Thanks for your time, I’ll explain my results.
Just tested it. It works nice now, 0 packets lost and fast working.
Thank you!!!
