@htdvisser
In MQTT integration, there is parameter “airtime”, but in HTTP there is not “airtime” included.
Is there possibility to get this parameter in HTTP also?
@htdvisser
Just in case you didn’t know: the airtime is not being measured somehow. Instead, it’s simply calculated by TTN, using the equations from Semtech’s AN1200.13 LoRa Modem Designer’s Guide.
See, e.g., implementations in:
Thanks for the info.
To get an uniform interface it would be nice that the parameter “airtime” is added to the http integration.
AlainD
Did you end up calculating the airtime yourself? I’m too migrating from MQTT to HTTP integration and ran into this issue where airtime is not reported via HTTP
The only solution is to calculate it yourself, which is all TTN do - as they aren’t adding any new features to v2.
no, up to now have not found the need.
