Thanks Dave, This will help in the short term.
Ultimately I would like to find a MicroPython version that will run on the TTGO and similar hardware as a LoRaWan client. I have a group of MicroPython enthusiasts who are all interested in developing simple low cost application nodes.
Peter,
The LoPy runs a variant of MicroPython. The guys at Core Electronics have them running LoRaWAN, so porting their libraries to ‘generic ESP32’ may be worth looking at.
Thanks for that.
I am familar with Pycom. I am using Lopy4 and FiPy in some projects.
I have seen someones attempt to use the lorawan library code (ex arduino) and port this across to micropython and TTGO, but have not been able to get full details yet. I need a piece of pre-packaged code that I can just install on the TTGO. My experience at building such is not good.
Perhaps it is a good idea to see if we can come up with a crowdsourced breakout board to use an RFM95 with any of the ESP32 boards that work well on low power. With a wemos d1 mini / RFM95 combo with one of Charles Hallard’s breakoutboards I got down to very low (<mA) figures. Would be nice to get such figures from the ESP32’s as they have great abilities for deep sleep (longer than an hour), interrupts and the ULP processor.
Perhaps Andreas Spiess’ overview of current ESP32 offerings is a good starting point:
I just finished a ESP32 based version of one of my tracker boards, based on LoRa DRF127x and with connections for a GPS and a couple of I2C sensors or displays, sleep current in non WiFi mode is 11uA. If you want to use the ESP32 WiFi you need to use a different regulator and sleep current rises by 25uA or so.
If anyone is interested in DIY and exploring low current standby of the ESP32, I have a number of the boards below you can have at cost + postage.
It can be powered by USB or battery with a choice of regulator. MCP1700 for a total sleep current of 11uA, or the SOIC regulator shown for a sleep current of 38uA. The SOIC regulator will cope with the WiFi switch on pulse.
No USB to serial converter on board, hence the very low sleep current. Program with a standard low cost USB to serial adapter.
I now realize that charles hallard has already done so months ago. Are there recommendations for esp32 / rfm95 breakoutboards that do not use the mini flowed capacitors, solder friendly?
Just a followup.
I have edited my lmic_as923.c to make both the default channels F1, and now I’m not missing every second one.
I’ll put it back to be standard.
Dave
Attention users of TTGO21 v1.6 (boards labeled “T3_V1.6” on pcb): During a test run on battery after about 30 minutes the battery exploded and got on fire. Board and battery burned down to nearly nothing in less then 30 seconds.
I used a Li-Po battery 3,7V / 840mAh. It was properly connected to the board, since the board did boot and run on battery. I then connected the board additionally to a 1A USB wallcharger using it’s USB port.
Since there is nothing left after board and battery burned down, i cannot investigate what happened.
But i remember that i wondered about the voltage measurement which was shown by my software, using the voltage divider on board: It showed 5,024 Volt. If this is really correct - and i assume it is - it means that there must be a hardware design error on the board which is causing a direct connection of the battery to USB 5V.
or the protection circuit failed or was not even there … but you cannot ever charge a lipo with more then 4.25 volts, could be a faillure in the dc/dc to
I used a Li-Po battery 3,7V / 840mAh. I then connected the board additionally to a 1A USB wallcharger
If the power/charging circuit is designed similar to the Adafruit Huzzah32 then in this configuration the battery is being trickle charged (hopefully with a charge current <= 500mA) if you hooked it up via the JSTPH2 connector, and the board is using the power from the USB, right? Also the voltage measurement (on the voltage divider) is that of the USB power (not the battery) if the USB cable is connected; I also got that on the graph.
The only battery problems I have encountered was when connecting unprotected Lifepo4 batteries using the JSTPH2 connector and powering the board using the USB cable. Then the board tries to charge the battery up to 4.25V which is a problem if the LiFePO4 battery does not have a protection circuit. I lost a few batteries because of that (but none started to smoke).
Perhaps it was a short in the battery itself. I hope
