Best practices to limit application payloads
Unless you’re using confirmed uplinks for the first uplink, I guess you’d need to send the LPP details a few times, to be (quite) sure they arrive. But the idea would be the same.
However, I’ve never understood the need to do the administration in the node. Like I wrote elsewhere:
And as an aside:
Don’t forget negative temperatures :wink:
