Arduino Pro Mini RFM95 pinmap problem
I tried both with Arduino Uno and Nano Every and I get the sane error. I’ve tested MCCI LoRaWAN LMIC, too. Beside the oslmic.c:53 error in the serial monitor, I get a pinmap error in the compiler. Wiring is ok, so I guess I have to accept that it’s a soldering problem, due to my terrible soldering skills. I’ll post some pics of that.
Your Gnd joint looks like it could be a dry joint.
I’d touch each of them up looking to remove the excess solder and make sure it flows like a liquid. The soldering iron tip can not transfer any heat by itself, there must be a small amount of solder on it to do that for you. But not so much that you can start sculpting with it.
I think you’ll see it’s a warning about you having to define the pin map, not an error.
I’d stick with the Nano Every - far more room for both program and variables.
You don’t need to test MCCI LMIC, it definitely works (I was coding on it most of the weekend), you just have to tell it which pins are being used for NSS, DIO0 and DIO1. Once you’ve got that going, you can focus on the EUI’s & AppKey.
With the appropriate 5V to 3.3V Logic level conversion circuits I presume.
That device does not look like any of the Hope RFM95s I have seen. Hope normally have a different marking on the RF chip they use RF95.
I would alse be very cautious wiring LoRa modules up like that, if the antenna wire becomes disconnected when you attempt to transmit it could let the devices magic smoke out.
Thank you. I’ll proceed with the soldering tips you gave me, trying to fix it. And then try again with LMIC. I’ll update you. (By the way, I’m using a “single channel” Raspberry Pi 4 Lora Gateway, I saw in the forum that it’s not a good idea)
Eeeehm, nope. I am not using a logic level converter… I saw video on youtube of people not using it… By the way, I also have a Hope LoRa module, but I think I’ve damaged it.
So not only, zapping 3.3V module with 5V and solder bridges but also …
We don’t say it’s not a good idea, we say they should not be used due to the disruption to the network. And you have to alter LMIC to be able to cope with a SPCF which isn’t trivial.
Please disconnect immediately and read: Single Channel Packet Forwarders (SCPF) are obsolete and not supported
If you want to make some progress, get a TTIG for a gateway and buy a board supported by LMIC-node. I’d normally recommend the Adafruit Feather M0 with RFM95 but in this instance, as it requires some delicate soldering, maybe best to pick something else. :wink:
Thanks for your rapid answer and kind suggestions! Do you think I still can make it with Arduino Nano Every, 3.3 to 5 V logic level converter and a Hope module?
I’ve a test device with a Nano Every and I have my own PCB with an ATmega4808 + RFM95 on it, it works fine with LMIC once you know LMIC.
You may want to use a breadboard & jumper cables until you’ve refined your soldering technique.
You still need a proper gateway.
I have the same problem with Dragino Lora Shield + Arduino Uno.
When I use your program, I get only this.
Capture
I am not told weather the lora device is found or not.
Any advice for me?
There are no writes to the LoRa device, something strange there.
Look at the code, It has to print found or not found;
if (begin(NSS))
    Serial.println(F("LoRa Device found"));
  else
    Serial.println(F("No device responding"));
Which TTN library have you tried ?
An additional comment: Some of the registers are not what the should be, so it looks like there are read problems over the SPI bus.
As per the program notes the startup should be:
2_Register_Test Starting
LoRa Device found
Device version 0x12
Frequency at Start 434000000
Registers at Start
Reg    0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
0x00  00 09 1A 0B 00 52 6C 80 00 4F 09 2B 20 08 02 0A
etc.
Thanks for the reply, I think I purchased a faulty dragino lora shield. Even the light on the shield was not turning one, once it was connected to power.
I think it was a faulty one.
Good morning,
I am using an Arduino Mega 2560 board with a LoRa Shield RFM95W radio module. However I use LMIC to send my data to a Dragino LPS8N gateway.
And when I upload my program to the Arduino board nothing happens and I get the error displayed on the serial monitor:
Arduino\libraries\LMIC-Arduino\src\lmic\radio.c:689
Here is the picture of the shield :slight_smile:
Help me please.
Here is my test code on arduino:
const int Pintest =13;
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// LoRaWAN NwkSKey, network session key
// This is the default Semtech key, which is used by the early prototype TTN
// network.
static const PROGMEM u1_t NWKSKEY[16] = { 0x91, 0xA4, 0xAE, 0x05, 0x61, 0x89, 0x16, 0xCF, 0x09, 0x73, 0x51, 0x70, 0x19, 0xD1, 0xC3, 0xE2 };
// LoRaWAN AppSKey, application session key
// network.
static const u1_t PROGMEM APPSKEY[16] = { 0x79, 0xDB, 0xD8, 0xE4, 0x98, 0xF8, 0x19, 0xE1, 0xA6, 0x52, 0x5D, 0x4F, 0x79, 0x43, 0x71, 0x5D };
// LoRaWAN end-device address (DevAddr)
static const u4_t DEVADDR = 0x010C2D70; // ← Change this address for every node!
// These callbacks are only used in over-the-air activation, so they are
// left empty here (we cannot leave them out completely unless
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
void os_getArtEui (u1_t* buf) { }
void os_getDevEui (u1_t* buf) { }
void os_getDevKey (u1_t* buf) { }
static uint8_t mydata = “Hello, world!”;
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 10;
// Pin mapping
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F(“EV_SCAN_TIMEOUT”));
break;
case EV_BEACON_FOUND:
Serial.println(F(“EV_BEACON_FOUND”));
break;
case EV_BEACON_MISSED:
Serial.println(F(“EV_BEACON_MISSED”));
break;
case EV_BEACON_TRACKED:
Serial.println(F(“EV_BEACON_TRACKED”));
break;
case EV_JOINING:
Serial.println(F(“EV_JOINING”));
break;
case EV_JOINED:
Serial.println(F(“EV_JOINED”));
break;
case EV_RFU1:
Serial.println(F(“EV_RFU1”));
break;
case EV_JOIN_FAILED:
Serial.println(F(“EV_JOIN_FAILED”));
break;
case EV_REJOIN_FAILED:
Serial.println(F(“EV_REJOIN_FAILED”));
break;
case EV_TXCOMPLETE:
Serial.println(F(“EV_TXCOMPLETE (includes waiting for RX windows)”));
Serial.println(F(“Received ack”));
if (LMIC.dataLen) {
Serial.println(F(“Received “));
Serial.println(LMIC.dataLen);
Serial.println(F(” bytes of payload”));
// Schedule next transmission
break;
case EV_LOST_TSYNC:
Serial.println(F(“EV_LOST_TSYNC”));
break;
case EV_RESET:
Serial.println(F(“EV_RESET”));
break;
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F(“EV_RXCOMPLETE”));
break;
case EV_LINK_DEAD:
Serial.println(F(“EV_LINK_DEAD”));
break;
case EV_LINK_ALIVE:
Serial.println(F(“EV_LINK_ALIVE”));
break;
default:
Serial.println(F(“Unknown event”));
break;
void do_send(osjob_t* j){
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
     uint8_t buff[3];
     buff[0] = 1;
    LMIC_setTxData2(1, buff, sizeof(buff), 0);
void setup() {
Serial.begin(115200);
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
pinMode(Pintest, OUTPUT);
// LMIC init
os_init();
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100);
// Set static session parameters. Instead of dynamically establishing a session
// by joining the network, precomputed session parameters are be provided.
#ifdef PROGMEM
// On AVR, these values are stored in flash and only copied to RAM
// once. Copy them to a temporary buffer here, LMIC_setSession will
// copy them into a buffer of its own again.
uint8_t appskey[sizeof(APPSKEY)];
uint8_t nwkskey[sizeof(NWKSKEY)];
memcpy_P(appskey, APPSKEY, sizeof(APPSKEY));
memcpy_P(nwkskey, NWKSKEY, sizeof(NWKSKEY));
LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
#else
// If not running an AVR with PROGMEM, just use the arrays directly
LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_eu868)
// Set up the channels used by the Things Network, which corresponds
// to the defaults of most gateways. Without this, only three base
// channels from the LoRaWAN specification are used, which certainly
// works, so it is good for debugging, but can overload those
// frequencies, so be sure to configure the full frequency range of
// your network here (unless your network autoconfigures them).
// Setting up channels should happen after LMIC_setSession, as that
// configures the minimal channel set.
// NA-US channels 0-71 are configured automatically
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);      // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK,  DR_FSK),  BAND_MILLI);      // g2-band
#elif defined(CFG_us915)
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
LMIC_selectSubBand(1);
#endif
// Disable link check validation
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
// Start job
do_send(&sendjob);
void loop() {
// put your main code here, to run repeatedly:
os_runloop_once();
digitalWrite(Pintest,HIGH);
delay(1000);
digitalWrite(Pintest,LOW);
delay(1000);
What does it say on this line of the code?
This is the line
Sorry, my screen reader can’t cope with images and neither can the forum. Please post text as text formatted using the </> tool. But don’t worry, I already know what’s on that line, I was wondering if you did.
But as, like others before you, I don’t see any thoughts on what it might mean.
Ok I will put the code using the </> tool. No I don’t know what exactly I’m a beginner on LMIC.
Do you have a solution for this problem
type or paste code here
 * Copyright (c) 2014-2015 IBM Corporation.
 * All rights reserved. This program and the accompanying materials
 * are made available under the terms of the Eclipse Public License v1.0
 * which accompanies this distribution, and is available at
 * http://www.eclipse.org/legal/epl-v10.html
 * Contributors:
 *    IBM Zurich Research Lab - initial API, implementation and documentation
#include "lmic.h"
// Registers Mapping
#define RegFifo                                    0x00 // common
#define RegOpMode                                  0x01 // common
#define FSKRegBitrateMsb                           0x02
#define FSKRegBitrateLsb                           0x03
#define FSKRegFdevMsb                              0x04
#define FSKRegFdevLsb                              0x05
#define RegFrfMsb                                  0x06 // common
#define RegFrfMid                                  0x07 // common
#define RegFrfLsb                                  0x08 // common
#define RegPaConfig                                0x09 // common
#define RegPaRamp                                  0x0A // common
#define RegOcp                                     0x0B // common
#define RegLna                                     0x0C // common
#define FSKRegRxConfig                             0x0D
#define LORARegFifoAddrPtr                         0x0D
#define FSKRegRssiConfig                           0x0E
#define LORARegFifoTxBaseAddr                      0x0E
#define FSKRegRssiCollision                        0x0F
#define LORARegFifoRxBaseAddr                      0x0F
#define FSKRegRssiThresh                           0x10
#define LORARegFifoRxCurrentAddr                   0x10
#define FSKRegRssiValue                            0x11
#define LORARegIrqFlagsMask                        0x11
#define FSKRegRxBw                                 0x12
#define LORARegIrqFlags                            0x12
#define FSKRegAfcBw                                0x13
#define LORARegRxNbBytes                           0x13
#define FSKRegOokPeak                              0x14
#define LORARegRxHeaderCntValueMsb                 0x14
#define FSKRegOokFix                               0x15
#define LORARegRxHeaderCntValueLsb                 0x15
#define FSKRegOokAvg                               0x16
#define LORARegRxPacketCntValueMsb                 0x16
#define LORARegRxpacketCntValueLsb                 0x17
#define LORARegModemStat                           0x18
#define LORARegPktSnrValue                         0x19
#define FSKRegAfcFei                               0x1A
#define LORARegPktRssiValue                        0x1A
#define FSKRegAfcMsb                               0x1B
#define LORARegRssiValue                           0x1B
#define FSKRegAfcLsb                               0x1C
#define LORARegHopChannel                          0x1C
#define FSKRegFeiMsb                               0x1D
#define LORARegModemConfig1                        0x1D
#define FSKRegFeiLsb                               0x1E
#define LORARegModemConfig2                        0x1E
#define FSKRegPreambleDetect                       0x1F
#define LORARegSymbTimeoutLsb                      0x1F
#define FSKRegRxTimeout1                           0x20
#define LORARegPreambleMsb                         0x20
#define FSKRegRxTimeout2                           0x21
#define LORARegPreambleLsb                         0x21
#define FSKRegRxTimeout3                           0x22
#define LORARegPayloadLength                       0x22
#define FSKRegRxDelay                              0x23
#define LORARegPayloadMaxLength                    0x23
#define FSKRegOsc                                  0x24
#define LORARegHopPeriod                           0x24
#define FSKRegPreambleMsb                          0x25
#define LORARegFifoRxByteAddr                      0x25
#define LORARegModemConfig3                        0x26
#define FSKRegPreambleLsb                          0x26
#define FSKRegSyncConfig                           0x27
#define LORARegFeiMsb                              0x28
#define FSKRegSyncValue1                           0x28
#define LORAFeiMib                                 0x29
#define FSKRegSyncValue2                           0x29
#define LORARegFeiLsb                              0x2A
#define FSKRegSyncValue3                           0x2A
#define FSKRegSyncValue4                           0x2B
#define LORARegRssiWideband                        0x2C
#define FSKRegSyncValue5                           0x2C
#define FSKRegSyncValue6                           0x2D
#define FSKRegSyncValue7                           0x2E
#define FSKRegSyncValue8                           0x2F
#define FSKRegPacketConfig1                        0x30
#define FSKRegPacketConfig2                        0x31
#define LORARegDetectOptimize                      0x31
#define FSKRegPayloadLength                        0x32
#define FSKRegNodeAdrs                             0x33
#define LORARegInvertIQ                            0x33
#define FSKRegBroadcastAdrs                        0x34
#define FSKRegFifoThresh                           0x35
#define FSKRegSeqConfig1                           0x36
#define FSKRegSeqConfig2                           0x37
#define LORARegDetectionThreshold                  0x37
#define FSKRegTimerResol                           0x38
#define FSKRegTimer1Coef                           0x39
#define LORARegSyncWord                            0x39
#define FSKRegTimer2Coef                           0x3A
#define FSKRegImageCal                             0x3B
#define FSKRegTemp                                 0x3C
#define FSKRegLowBat                               0x3D
#define FSKRegIrqFlags1                            0x3E
#define FSKRegIrqFlags2                            0x3F
#define RegDioMapping1                             0x40 // common
#define RegDioMapping2                             0x41 // common
#define RegVersion                                 0x42 // common
// #define RegAgcRef                                  0x43 // common
// #define RegAgcThresh1                              0x44 // common
// #define RegAgcThresh2                              0x45 // common
// #define RegAgcThresh3                              0x46 // common
// #define RegPllHop                                  0x4B // common
// #define RegTcxo                                    0x58 // common
#define RegPaDac                                   0x5A // common
// #define RegPll                                     0x5C // common
// #define RegPllLowPn                                0x5E // common
// #define RegFormerTemp                              0x6C // common
// #define RegBitRateFrac                             0x70 // common
// spread factors and mode for RegModemConfig2
#define SX1272_MC2_FSK  0x00
#define SX1272_MC2_SF7  0x70
#define SX1272_MC2_SF8  0x80
#define SX1272_MC2_SF9  0x90
#define SX1272_MC2_SF10 0xA0
#define SX1272_MC2_SF11 0xB0
#define SX1272_MC2_SF12 0xC0
// bandwidth for RegModemConfig1
#define SX1272_MC1_BW_125  0x00
#define SX1272_MC1_BW_250  0x40
#define SX1272_MC1_BW_500  0x80
// coding rate for RegModemConfig1
#define SX1272_MC1_CR_4_5 0x08
#define SX1272_MC1_CR_4_6 0x10
#define SX1272_MC1_CR_4_7 0x18
#define SX1272_MC1_CR_4_8 0x20
#define SX1272_MC1_IMPLICIT_HEADER_MODE_ON 0x04 // required for receive
#define SX1272_MC1_RX_PAYLOAD_CRCON        0x02
#define SX1272_MC1_LOW_DATA_RATE_OPTIMIZE  0x01 // mandated for SF11 and SF12
// transmit power configuration for RegPaConfig
#define SX1272_PAC_PA_SELECT_PA_BOOST 0x80
#define SX1272_PAC_PA_SELECT_RFIO_PIN 0x00
// sx1276 RegModemConfig1
#define SX1276_MC1_BW_125                0x70
#define SX1276_MC1_BW_250                0x80
#define SX1276_MC1_BW_500                0x90
#define SX1276_MC1_CR_4_5            0x02
#define SX1276_MC1_CR_4_6            0x04
#define SX1276_MC1_CR_4_7            0x06
#define SX1276_MC1_CR_4_8            0x08
#define SX1276_MC1_IMPLICIT_HEADER_MODE_ON    0x01
// sx1276 RegModemConfig2
#define SX1276_MC2_RX_PAYLOAD_CRCON        0x04
// sx1276 RegModemConfig3
#define SX1276_MC3_LOW_DATA_RATE_OPTIMIZE  0x08
#define SX1276_MC3_AGCAUTO                 0x04
// preamble for lora networks (nibbles swapped)
#define LORA_MAC_PREAMBLE                  0x34
#define RXLORA_RXMODE_RSSI_REG_MODEM_CONFIG1 0x0A
#ifdef CFG_sx1276_radio
#define RXLORA_RXMODE_RSSI_REG_MODEM_CONFIG2 0x70
#elif CFG_sx1272_radio
#define RXLORA_RXMODE_RSSI_REG_MODEM_CONFIG2 0x74
#endif
// Constants for radio registers
#define OPMODE_LORA      0x80
#define OPMODE_MASK      0x07
#define OPMODE_SLEEP     0x00
#define OPMODE_STANDBY   0x01
#define OPMODE_FSTX      0x02
#define OPMODE_TX        0x03
#define OPMODE_FSRX      0x04
#define OPMODE_RX        0x05
#define OPMODE_RX_SINGLE 0x06
#define OPMODE_CAD       0x07
// Bits masking the corresponding IRQs from the radio
#define IRQ_LORA_RXTOUT_MASK 0x80
#define IRQ_LORA_RXDONE_MASK 0x40
#define IRQ_LORA_CRCERR_MASK 0x20
#define IRQ_LORA_HEADER_MASK 0x10
#define IRQ_LORA_TXDONE_MASK 0x08
#define IRQ_LORA_CDDONE_MASK 0x04
#define IRQ_LORA_FHSSCH_MASK 0x02
#define IRQ_LORA_CDDETD_MASK 0x01
#define IRQ_FSK1_MODEREADY_MASK         0x80
#define IRQ_FSK1_RXREADY_MASK           0x40
#define IRQ_FSK1_TXREADY_MASK           0x20
#define IRQ_FSK1_PLLLOCK_MASK           0x10
#define IRQ_FSK1_RSSI_MASK              0x08
#define IRQ_FSK1_TIMEOUT_MASK           0x04
#define IRQ_FSK1_PREAMBLEDETECT_MASK    0x02
#define IRQ_FSK1_SYNCADDRESSMATCH_MASK  0x01
#define IRQ_FSK2_FIFOFULL_MASK          0x80
#define IRQ_FSK2_FIFOEMPTY_MASK         0x40
#define IRQ_FSK2_FIFOLEVEL_MASK         0x20
#define IRQ_FSK2_FIFOOVERRUN_MASK       0x10
#define IRQ_FSK2_PACKETSENT_MASK        0x08
#define IRQ_FSK2_PAYLOADREADY_MASK      0x04
#define IRQ_FSK2_CRCOK_MASK             0x02
#define IRQ_FSK2_LOWBAT_MASK            0x01
// DIO function mappings                D0D1D2D3
#define MAP_DIO0_LORA_RXDONE   0x00  // 00------
#define MAP_DIO0_LORA_TXDONE   0x40  // 01------
#define MAP_DIO1_LORA_RXTOUT   0x00  // --00----
#define MAP_DIO1_LORA_NOP      0x30  // --11----
#define MAP_DIO2_LORA_NOP      0xC0  // ----11--
#define MAP_DIO0_FSK_READY     0x00  // 00------ (packet sent / payload ready)
#define MAP_DIO1_FSK_NOP       0x30  // --11----
#define MAP_DIO2_FSK_TXNOP     0x04  // ----01--
#define MAP_DIO2_FSK_TIMEOUT   0x08  // ----10--
// FSK IMAGECAL defines
#define RF_IMAGECAL_AUTOIMAGECAL_MASK               0x7F
#define RF_IMAGECAL_AUTOIMAGECAL_ON                 0x80
#define RF_IMAGECAL_AUTOIMAGECAL_OFF                0x00  // Default
#define RF_IMAGECAL_IMAGECAL_MASK                   0xBF
#define RF_IMAGECAL_IMAGECAL_START                  0x40
#define RF_IMAGECAL_IMAGECAL_RUNNING                0x20
#define RF_IMAGECAL_IMAGECAL_DONE                   0x00  // Default
// RADIO STATE
// (initialized by radio_init(), used by radio_rand1())
static u1_t randbuf[16];
#define LNA_RX_GAIN (0x20|0x1)
#define LNA_RX_GAIN (0x20|0x03)
#else
#error Missing CFG_sx1272_radio/CFG_sx1276_radio
#endif
static void writeReg (u1_t addr, u1_t data ) {
    hal_pin_nss(0);
    hal_spi(addr | 0x80);
    hal_spi(data);
    hal_pin_nss(1);
static u1_t readReg (u1_t addr) {
    hal_pin_nss(0);
    hal_spi(addr & 0x7F);
    u1_t val = hal_spi(0x00);
    hal_pin_nss(1);
    return val;
static void writeBuf (u1_t addr, xref2u1_t buf, u1_t len) {
    hal_pin_nss(0);
    for (u1_t i=0; i<len; i++) {
        hal_spi(buf[i]);
    hal_pin_nss(1);
static void readBuf (u1_t addr, xref2u1_t buf, u1_t len) {
    hal_pin_nss(0);
        buf[i] = hal_spi(0x00);
    hal_pin_nss(1);
static void opmode (u1_t mode) {
    writeReg(RegOpMode, (readReg(RegOpMode) & ~OPMODE_MASK) | mode);
static void opmodeLora() {
    u1_t u = OPMODE_LORA;
    u |= 0x8;   // TBD: sx1276 high freq
#endif
    writeReg(RegOpMode, u);
static void opmodeFSK() {
    u1_t u = 0;
#endif
// configure LoRa modem (cfg1, cfg2)
static void configLoraModem () {
    sf_t sf = getSf(LMIC.rps);
        u1_t mc1 = 0, mc2 = 0, mc3 = 0;
        switch (getBw(LMIC.rps)) {
        case BW125: mc1 |= SX1276_MC1_BW_125; break;
        case BW250: mc1 |= SX1276_MC1_BW_250; break;
        case BW500: mc1 |= SX1276_MC1_BW_500; break;
        default:
            ASSERT(0);
        switch( getCr(LMIC.rps) ) {
        case CR_4_5: mc1 |= SX1276_MC1_CR_4_5; break;
        case CR_4_6: mc1 |= SX1276_MC1_CR_4_6; break;
        case CR_4_7: mc1 |= SX1276_MC1_CR_4_7; break;
        case CR_4_8: mc1 |= SX1276_MC1_CR_4_8; break;
        default:
            ASSERT(0);
        if (getIh(LMIC.rps)) {
            mc1 |= SX1276_MC1_IMPLICIT_HEADER_MODE_ON;
            writeReg(LORARegPayloadLength, getIh(LMIC.rps)); // required length
        // set ModemConfig1
        writeReg(LORARegModemConfig1, mc1);
        mc2 = (SX1272_MC2_SF7 + ((sf-1)<<4));
        if (getNocrc(LMIC.rps) == 0) {
            mc2 |= SX1276_MC2_RX_PAYLOAD_CRCON;
        writeReg(LORARegModemConfig2, mc2);
        mc3 = SX1276_MC3_AGCAUTO;
        if ((sf == SF11 || sf == SF12) && getBw(LMIC.rps) == BW125) {
            mc3 |= SX1276_MC3_LOW_DATA_RATE_OPTIMIZE;
        writeReg(LORARegModemConfig3, mc3);
        u1_t mc1 = (getBw(LMIC.rps)<<6);
        case CR_4_5: mc1 |= SX1272_MC1_CR_4_5; break;
        case CR_4_6: mc1 |= SX1272_MC1_CR_4_6; break;
        case CR_4_7: mc1 |= SX1272_MC1_CR_4_7; break;
        case CR_4_8: mc1 |= SX1272_MC1_CR_4_8; break;
            mc1 |= SX1272_MC1_LOW_DATA_RATE_OPTIMIZE;
            mc1 |= SX1272_MC1_RX_PAYLOAD_CRCON;
            mc1 |= SX1272_MC1_IMPLICIT_HEADER_MODE_ON;
        // set ModemConfig1
        // set ModemConfig2 (sf, AgcAutoOn=1 SymbTimeoutHi=00)
        writeReg(LORARegModemConfig2, (SX1272_MC2_SF7 + ((sf-1)<<4)) | 0x04);
#else
#endif /* CFG_sx1272_radio */
static void configChannel () {
    // set frequency: FQ = (FRF * 32 Mhz) / (2 ^ 19)
    uint64_t frf = ((uint64_t)LMIC.freq << 19) / 32000000;
    writeReg(RegFrfMsb, (u1_t)(frf>>16));
    writeReg(RegFrfMid, (u1_t)(frf>> 8));
    writeReg(RegFrfLsb, (u1_t)(frf>> 0));
static void configPower () {
    // no boost used for now
    s1_t pw = (s1_t)LMIC.txpow;
    if(pw >= 17) {
        pw = 15;
    } else if(pw < 2) {
        pw = 2;
    // check board type for BOOST pin
    writeReg(RegPaConfig, (u1_t)(0x80|(pw&0xf)));
    writeReg(RegPaDac, readReg(RegPaDac)|0x4);
    // set PA config (2-17 dBm using PA_BOOST)
    if(pw > 17) {
        pw = 17;
    } else if(pw < 2) {
        pw = 2;
    writeReg(RegPaConfig, (u1_t)(0x80|(pw-2)));
#else
static void txfsk () {
    // select FSK modem (from sleep mode)
    writeReg(RegOpMode, 0x10); // FSK, BT=0.5
    ASSERT(readReg(RegOpMode) == 0x10);
    // enter standby mode (required for FIFO loading))
    opmode(OPMODE_STANDBY);
    // set bitrate
    writeReg(FSKRegBitrateMsb, 0x02); // 50kbps
    writeReg(FSKRegBitrateLsb, 0x80);
    // set frequency deviation
    writeReg(FSKRegFdevMsb, 0x01); // +/- 25kHz
    writeReg(FSKRegFdevLsb, 0x99);
    // frame and packet handler settings
    writeReg(FSKRegPreambleMsb, 0x00);
    writeReg(FSKRegPreambleLsb, 0x05);
    writeReg(FSKRegSyncConfig, 0x12);
    writeReg(FSKRegPacketConfig1, 0xD0);
    writeReg(FSKRegPacketConfig2, 0x40);
    writeReg(FSKRegSyncValue1, 0xC1);
    writeReg(FSKRegSyncValue2, 0x94);
    writeReg(FSKRegSyncValue3, 0xC1);
    // configure frequency
    configChannel();
    // configure output power
    configPower();
    // set the IRQ mapping DIO0=PacketSent DIO1=NOP DIO2=NOP
    writeReg(RegDioMapping1, MAP_DIO0_FSK_READY|MAP_DIO1_FSK_NOP|MAP_DIO2_FSK_TXNOP);
    // initialize the payload size and address pointers
    writeReg(FSKRegPayloadLength, LMIC.dataLen+1); // (insert length byte into payload))
    // download length byte and buffer to the radio FIFO
    writeReg(RegFifo, LMIC.dataLen);
    writeBuf(RegFifo, LMIC.frame, LMIC.dataLen);
    // enable antenna switch for TX
    hal_pin_rxtx(1);
    // now we actually start the transmission
    opmode(OPMODE_TX);
static void txlora () {
    // select LoRa modem (from sleep mode)
    //writeReg(RegOpMode, OPMODE_LORA);
    opmodeLora();
    ASSERT((readReg(RegOpMode) & OPMODE_LORA) != 0);
    configLoraModem();
    configChannel();
    writeReg(RegPaRamp, (readReg(RegPaRamp) & 0xF0) | 0x08); // set PA ramp-up time 50 uSec
    configPower();
    // set sync word
    writeReg(LORARegSyncWord, LORA_MAC_PREAMBLE);
    // set the IRQ mapping DIO0=TxDone DIO1=NOP DIO2=NOP
    writeReg(RegDioMapping1, MAP_DIO0_LORA_TXDONE|MAP_DIO1_LORA_NOP|MAP_DIO2_LORA_NOP);
    // clear all radio IRQ flags
    writeReg(LORARegIrqFlags, 0xFF);
    // mask all IRQs but TxDone
    writeReg(LORARegIrqFlagsMask, ~IRQ_LORA_TXDONE_MASK);
    writeReg(LORARegFifoTxBaseAddr, 0x00);
    writeReg(LORARegFifoAddrPtr, 0x00);
    writeReg(LORARegPayloadLength, LMIC.dataLen);
    // download buffer to the radio FIFO
    hal_pin_rxtx(1);
    opmode(OPMODE_TX);
#if LMIC_DEBUG_LEVEL > 0
    u1_t sf = getSf(LMIC.rps) + 6; // 1 == SF7
    u1_t bw = getBw(LMIC.rps);
    u1_t cr = getCr(LMIC.rps);
    lmic_printf("%lu: TXMODE, freq=%lu, len=%d, SF=%d, BW=%d, CR=4/%d, IH=%d\n",
           os_getTime(), LMIC.freq, LMIC.dataLen, sf,
           bw == BW125 ? 125 : (bw == BW250 ? 250 : 500),
           cr == CR_4_5 ? 5 : (cr == CR_4_6 ? 6 : (cr == CR_4_7 ? 7 : 8)),
           getIh(LMIC.rps)
#endif
// start transmitter (buf=LMIC.frame, len=LMIC.dataLen)
static void starttx () {
    ASSERT( (readReg(RegOpMode) & OPMODE_MASK) == OPMODE_SLEEP );
    if(getSf(LMIC.rps) == FSK) { // FSK modem
        txfsk();
    } else { // LoRa modem
        txlora();
    // the radio will go back to STANDBY mode as soon as the TX is finished
    // the corresponding IRQ will inform us about completion.
enum { RXMODE_SINGLE, RXMODE_SCAN, RXMODE_RSSI };
static CONST_TABLE(u1_t, rxlorairqmask)[] = {
    [RXMODE_SINGLE] = IRQ_LORA_RXDONE_MASK|IRQ_LORA_RXTOUT_MASK,
    [RXMODE_SCAN]   = IRQ_LORA_RXDONE_MASK,
    [RXMODE_RSSI]   = 0x00,
// start LoRa receiver (time=LMIC.rxtime, timeout=LMIC.rxsyms, result=LMIC.frame[LMIC.dataLen])
static void rxlora (u1_t rxmode) {
    opmodeLora();
    // enter standby mode (warm up))
    // don't use MAC settings at startup
    if(rxmode == RXMODE_RSSI) { // use fixed settings for rssi scan
        writeReg(LORARegModemConfig1, RXLORA_RXMODE_RSSI_REG_MODEM_CONFIG1);
        writeReg(LORARegModemConfig2, RXLORA_RXMODE_RSSI_REG_MODEM_CONFIG2);
    } else { // single or continuous rx mode
        configLoraModem();
        configChannel();
    // set LNA gain
    writeReg(RegLna, LNA_RX_GAIN);
    // set max payload size
    writeReg(LORARegPayloadMaxLength, 64);
#if !defined(DISABLE_INVERT_IQ_ON_RX)
    // use inverted I/Q signal (prevent mote-to-mote communication)
    writeReg(LORARegInvertIQ, readReg(LORARegInvertIQ)|(1<<6));
#endif
    // set symbol timeout (for single rx)
    writeReg(LORARegSymbTimeoutLsb, LMIC.rxsyms);
    // set sync word
    // configure DIO mapping DIO0=RxDone DIO1=RxTout DIO2=NOP
    writeReg(RegDioMapping1, MAP_DIO0_LORA_RXDONE|MAP_DIO1_LORA_RXTOUT|MAP_DIO2_LORA_NOP);
    // enable required radio IRQs
    writeReg(LORARegIrqFlagsMask, ~TABLE_GET_U1(rxlorairqmask, rxmode));
    // enable antenna switch for RX
    hal_pin_rxtx(0);
    // now instruct the radio to receive
    if (rxmode == RXMODE_SINGLE) { // single rx
        hal_waitUntil(LMIC.rxtime); // busy wait until exact rx time
        opmode(OPMODE_RX_SINGLE);
    } else { // continous rx (scan or rssi)
        opmode(OPMODE_RX);
    if (rxmode == RXMODE_RSSI) {
        lmic_printf("RXMODE_RSSI\n");
    } else {
        lmic_printf("%lu: %s, freq=%lu, SF=%d, BW=%d, CR=4/%d, IH=%d\n",
               os_getTime(),
               rxmode == RXMODE_SINGLE ? "RXMODE_SINGLE" : (rxmode == RXMODE_SCAN ? "RXMODE_SCAN" : "UNKNOWN_RX"),
               LMIC.freq, sf,
               getIh(LMIC.rps)
#endif
static void rxfsk (u1_t rxmode) {
    // only single rx (no continuous scanning, no noise sampling)
    ASSERT( rxmode == RXMODE_SINGLE );
    //writeReg(RegOpMode, 0x00); // (not LoRa)
    opmodeFSK();
    ASSERT((readReg(RegOpMode) & OPMODE_LORA) == 0);
    configChannel();
    // set LNA gain
    //writeReg(RegLna, 0x20|0x03); // max gain, boost enable
    // configure receiver
    writeReg(FSKRegRxConfig, 0x1E); // AFC auto, AGC, trigger on preamble?!?
    // set receiver bandwidth
    writeReg(FSKRegRxBw, 0x0B); // 50kHz SSb
    // set AFC bandwidth
    writeReg(FSKRegAfcBw, 0x12); // 83.3kHz SSB
    // set preamble detection
    writeReg(FSKRegPreambleDetect, 0xAA); // enable, 2 bytes, 10 chip errors
    // set sync config
    writeReg(FSKRegSyncConfig, 0x12); // no auto restart, preamble 0xAA, enable, fill FIFO, 3 bytes sync
    // set packet config
    writeReg(FSKRegPacketConfig1, 0xD8); // var-length, whitening, crc, no auto-clear, no adr filter
    writeReg(FSKRegPacketConfig2, 0x40); // packet mode
    // set sync value
    // set preamble timeout
    writeReg(FSKRegRxTimeout2, 0xFF);//(LMIC.rxsyms+1)/2);
    // set bitrate
    // configure DIO mapping DIO0=PayloadReady DIO1=NOP DIO2=TimeOut
    writeReg(RegDioMapping1, MAP_DIO0_FSK_READY|MAP_DIO1_FSK_NOP|MAP_DIO2_FSK_TIMEOUT);
    hal_pin_rxtx(0);
    opmode(OPMODE_RX); // no single rx mode available in FSK
static void startrx (u1_t rxmode) {
        rxfsk(rxmode);
        rxlora(rxmode);
    // the radio will go back to STANDBY mode as soon as the RX is finished
    // or timed out, and the corresponding IRQ will inform us about completion.
// get random seed from wideband noise rssi
void radio_init () {
    hal_disableIRQs();
    // manually reset radio
    hal_pin_rst(0); // drive RST pin low
#else
    hal_pin_rst(1); // drive RST pin high
#endif
    hal_waitUntil(os_getTime()+ms2osticks(1)); // wait >100us
    hal_pin_rst(2); // configure RST pin floating!
    hal_waitUntil(os_getTime()+ms2osticks(5)); // wait 5ms
    opmode(OPMODE_SLEEP);
    // some sanity checks, e.g., read version number
    u1_t v = readReg(RegVersion);
    ASSERT(v == 0x12 );
    ASSERT(v == 0x22);
#else
#endif
    // seed 15-byte randomness via noise rssi
    rxlora(RXMODE_RSSI);
    while( (readReg(RegOpMode) & OPMODE_MASK) != OPMODE_RX ); // continuous rx
    for(int i=1; i<16; i++) {
        for(int j=0; j<8; j++) {
            u1_t b; // wait for two non-identical subsequent least-significant bits
            while( (b = readReg(LORARegRssiWideband) & 0x01) == (readReg(LORARegRssiWideband) & 0x01) );
            randbuf[i] = (randbuf[i] << 1) | b;
    randbuf[0] = 16; // set initial index
#ifdef CFG_sx1276mb1_board
    // chain calibration
    writeReg(RegPaConfig, 0);
    // Launch Rx chain calibration for LF band
    writeReg(FSKRegImageCal, (readReg(FSKRegImageCal) & RF_IMAGECAL_IMAGECAL_MASK)|RF_IMAGECAL_IMAGECAL_START);
    while((readReg(FSKRegImageCal)&RF_IMAGECAL_IMAGECAL_RUNNING) == RF_IMAGECAL_IMAGECAL_RUNNING){ ; }
    // Sets a Frequency in HF band
    u4_t frf = 868000000;
    // Launch Rx chain calibration for HF band
    while((readReg(FSKRegImageCal) & RF_IMAGECAL_IMAGECAL_RUNNING) == RF_IMAGECAL_IMAGECAL_RUNNING) { ; }
#endif /* CFG_sx1276mb1_board */
    hal_enableIRQs();
// return next random byte derived from seed buffer
// (buf[0] holds index of next byte to be returned)
u1_t radio_rand1 () {
    u1_t i = randbuf[0];
    ASSERT( i != 0 );
    if( i==16 ) {
        os_aes(AES_ENC, randbuf, 16); // encrypt seed with any key
        i = 0;
    u1_t v = randbuf[i++];
    randbuf[0] = i;
    return v;
u1_t radio_rssi () {
    hal_disableIRQs();
    u1_t r = readReg(LORARegRssiValue);
    hal_enableIRQs();
    return r;
static CONST_TABLE(u2_t, LORA_RXDONE_FIXUP)[] = {
    [FSK]  =     us2osticks(0), // (   0 ticks)
    [SF7]  =     us2osticks(0), // (   0 ticks)
    [SF8]  =  us2osticks(1648), // (  54 ticks)
    [SF9]  =  us2osticks(3265), // ( 107 ticks)
    [SF10] =  us2osticks(7049), // ( 231 ticks)
    [SF11] = us2osticks(13641), // ( 447 ticks)
    [SF12] = us2osticks(31189), // (1022 ticks)
// called by hal ext IRQ handler
// (radio goes to stanby mode after tx/rx operations)
void radio_irq_handler (u1_t dio) {
    ostime_t now = os_getTime();
    if( (readReg(RegOpMode) & OPMODE_LORA) != 0) { // LORA modem
        u1_t flags = readReg(LORARegIrqFlags);
#if LMIC_DEBUG_LEVEL > 1
        lmic_printf("%lu: irq: dio: 0x%x flags: 0x%x\n", now, dio, flags);
#endif
        if( flags & IRQ_LORA_TXDONE_MASK ) {
            // save exact tx time
            LMIC.txend = now - us2osticks(43); // TXDONE FIXUP
        } else if( flags & IRQ_LORA_RXDONE_MASK ) {
            // save exact rx time
            if(getBw(LMIC.rps) == BW125) {
                now -= TABLE_GET_U2(LORA_RXDONE_FIXUP, getSf(LMIC.rps));
            LMIC.rxtime = now;
            // read the PDU and inform the MAC that we received something
            LMIC.dataLen = (readReg(LORARegModemConfig1) & SX1272_MC1_IMPLICIT_HEADER_MODE_ON) ?
                readReg(LORARegPayloadLength) : readReg(LORARegRxNbBytes);
            // set FIFO read address pointer
            writeReg(LORARegFifoAddrPtr, readReg(LORARegFifoRxCurrentAddr));
            // now read the FIFO
            readBuf(RegFifo, LMIC.frame, LMIC.dataLen);
            // read rx quality parameters
            LMIC.snr  = readReg(LORARegPktSnrValue); // SNR [dB] * 4
            LMIC.rssi = readReg(LORARegPktRssiValue) - 125 + 64; // RSSI [dBm] (-196...+63)
        } else if( flags & IRQ_LORA_RXTOUT_MASK ) {
            // indicate timeout
            LMIC.dataLen = 0;
        // mask all radio IRQs
        writeReg(LORARegIrqFlagsMask, 0xFF);
        // clear radio IRQ flags
    } else { // FSK modem
        u1_t flags1 = readReg(FSKRegIrqFlags1);
        u1_t flags2 = readReg(FSKRegIrqFlags2);
        if( flags2 & IRQ_FSK2_PACKETSENT_MASK ) {
            LMIC.txend = now;
        } else if( flags2 & IRQ_FSK2_PAYLOADREADY_MASK ) {
            LMIC.rxtime = now;
            LMIC.dataLen = readReg(FSKRegPayloadLength);
            LMIC.snr  = 0; // determine snr
            LMIC.rssi = 0; // determine rssi
        } else if( flags1 & IRQ_FSK1_TIMEOUT_MASK ) {
            // indicate timeout
            LMIC.dataLen = 0;
        } else {
            ASSERT(0);
    // go from stanby to sleep
    // run os job (use preset func ptr)
    os_setCallback(&LMIC.osjob, LMIC.osjob.func);
void os_radio (u1_t mode) {
    hal_disableIRQs();
    switch (mode) {
      case RADIO_RST:
        // put radio to sleep
        break;
      case RADIO_TX:
        // transmit frame now
        starttx(); // buf=LMIC.frame, len=LMIC.dataLen
        break;
      case RADIO_RX:
        // receive frame now (exactly at rxtime)
        startrx(RXMODE_SINGLE); // buf=LMIC.frame, time=LMIC.rxtime, timeout=LMIC.rxsyms
        break;
      case RADIO_RXON:
        // start scanning for beacon now
        startrx(RXMODE_SCAN); // buf=LMIC.frame
        break;
    hal_enableIRQs();
The entire file, really?
And text posted as text isn’t an option, it’s helping with the forum search, which you could try …
As well as reviewing the README relating to radio cfg as implied by the lines around 689 …
You could just paste the few lines concerned in stead of the entire file…
Can you use search? This isn’t the first time a question has been asked about this error. The last time was less than a week ago… also googling what an assert is used for might enlighten you what is wrong.
Hint, controller seems not get the right result from the rfm module. Are you pin mappings correct??
Sorry I thought you asked for the whole file.
I’m a debutant here.It’s my firts time on forums.
Yes I saw that some were talking about pin mapping problem. But how to check the pin mapping?
Sorry if my questions seem obvious to you, I just don’t understand.
And thank you in advance for your understanding.
