@w4e’s example works for static (ABP) devices. For dynamic (OTAA) devices, you can use the following:
❯ ttnctl devices register 0102030405060708
INFO Generating random AppKey...
INFO Registered device AppKey=45316EFBEFA00AE3CB10A323E9BD24E2 DevEUI=0102030405060708
Hi all, first of all congrats for the new backend!!
I was wondering that in case I would like to run a private network setup with this new TTN Backend, according to the wiki and this overview, I only have to create a Docker-compse file that includes the configuration there shown?
Thanks in advance,
Regards,
EDIT: I have tried that but I got errors in the broker that cannot connect to the account server, is that needed for private networks?
@htdvisser@w4e thanks! I can now join via ABP and receive messages with ttnctl subscribe.
However, if I try to use OTAA it fails to join. I’ve configured the Multitech MDOT with:
AT+PN (public network) - tried both 1 and 0. Not sure which it should be now?
AT+NK (network key/AppKey in Loramac) - set with AppKey
AT+NI (network ID/App EUI in Loramac) - set with AppEUI
I’ve registered the device with ttnctl using the full EUI (008000000000ADB3).
Also, how do you use ttnctl to de-register/delete a device?
And do you need to do anything else (on the gateway or via ttnctl) to enable acknowledged uplink?
You do need access to an account server. You can use TTN’s account server on https://account.thethingsnetwork.org. We’re still doing quite some development on this, but as soon as the API is stable, we’ll define a specification for this account server so that you can implement your own.
This could be caused by a number of things. For example if you have a single-channel gateway closeby (#140), if you’re not in Europe (#119 and #120) or some other unknown issue. Talk to me on Slack tomorrow (CEST) and I can try to help you.
That’s not possible yet, but it’s on our todo list.
Only use confirmed uplink if you really need it. It eats downlink capacity.
Thanks, @htdvisser. I’m in the UK and fairly sure there are not any other gateways nearby. I’m out of the office today, but will be back with the gateway tomorrow afternoon around 14:00 UTC.
Regarding confirmed uplink, I have a survey app from Multitech that uses this to measure downlink RSSI, which is then stored along with the GPS coordinates and timestamp. However, it just occurred to me that I should probably have been using the experimental branches from the Lora-net GitHub repos in order for the gateway to support ACKs.
Thanks @htdvisser , I understand it.So in that case if my private network cannot reach the internet, I cannot use the new backend from TTN till its API is stable right? I have noticed that the broker crashes if it cannot reach that server, so I commented it but still it was crashing.
In a private offline network (see wiki), you can implement your own authentication mechanism. It is still token-based, but you can issue your own tokens and disable authentication on MQTT, for example.
Yep… And the US frequencies in South America (except Brazil) and Canada. And there are a lot more exceptions, so we’ll probably build a list where you can find the correct frequency for each country.
Ah, that was the last missing puzzle piece in my application - that the DevEUI in the mqtt topic is the DevAddr (like 02E00202) with 8 pre-pended zeros. Actually discovered it by subscribing with wildcards ( +/devices/+/up ) in nodejs, and then printing out the topic when a message came in! Working great now…
We’re using tokens to authenticate and authorize users and applications. The tokens are issued by the account server. You can issue your own tokens if you implement your own account server too. We did not publish specifications for that yet because it is still in development. Tokens are signed with a private key and can be validated with a public key. This public key is required in the Broker to check if the token from the client (e.g. ttnctl) is valid.
It looks like you try to get the wrong key; the Broker tries to get the public key for validating the token from https://account.thethingsnetwork.org/key. The Broker tries this on start-up. If it fails, because there’s no internet, then the cached key is used. So make sure that your start the Broker at least once with an internet connection.
I use the standard command and I’m getting the following error message. I’ve managed to get the re-configured etc.
Setup up new account and password
Setup and Application
Associate the application
./ttnctl devices register personalized 02D1DD03
INFO Generating random NwkSKey and AppSKey…
FATAL Could not register device error=rpc error: code = 2 desc = Invalid operation: rpc error: code = 2 desc = Invalid operation: Unauthorized
Did you use the ttnctl applications use <AppEUI> command to activate your newly created application? See the AppEUI in the overview you get with ttnctl applications.
