Fwiw perhaps our efforts to develop a cheap air quality monitor might be of interest, see http://ourairquality.org/ This design uses a NodeMCU/esp8266 Wifi board and the esp-open-rtos framework. It supports the Plantower PMSx003 family of sensors, and the BME280 and a few other temperature and humidity sensors. A dc3231 real-time-clock is supported as an option. Some features that might differentiate it are:
It records all the data from the PM sensor, more that one sample a second. This might help with quickly changing air quality, such as is common from close sources of pollution, and with mapping.
It compresses the data and can store a few days of data on the NodeMCU flash, a circular buffer. This allows it to work offline for a few days, or with intermittent Internet access without losing data.
The compressed data can be pushed to a server or pulled from the device.
It is designed to minimise data manipulation in the data logger and stores the complete raw data from the PM sensor including the crc, and logs data as a journal. This is an attempt to make it more credible on cross examination.
A wall mounted case is also described, folded from a single piece of fluted plastic. This is a attempt (perhaps misguided) to make a cheap case.
The server side software is not as well developed and still under development.
