About the Malaysia category
Hi everyone, I have a Gateway Rak2245 and wanted to set it up to the AS 923 Mhz Channel TTN channel plan. I am a litlle unsure wheter do i required to get a license from MCMC for that frequency?
I am working on a lora esp32 module of 433MHz that sends data to the gateway in Penang.
And
Different frequencies. Will not work.
Hi Jac! Thanks for the info.
However, from what I learned and planned was to connect the gateway to the AS923 MHz since it is the available frequency in Malaysia. The gateway is connect to the AS923 MHz via TTN as for the real time frequency will be 433MHz since I have a TTGO LoRa ESP 32 node that is build for 433MHz.
Also if I were to use 443MHz frequency in Malaysia, it only gives the option for that for the Europe region EU433 in chirpstack. Can I still use it?
Is my method correct? Do let me know your thoughts on this
923MHz hardware is tuned for that frequency. It won’t be able to receive 433Mhz signals. You can’t use a gateway for a frequency it is not designed for.
