The WORKBENCH part 1
Yes I’ll mount a fuse between AC and the HiLINK.
X488
Also a 2 color LED, red on power on (plugged in) and green flashing when it can reach a gateway, green continue when the coffee machine/tv is on and a notification is transmitted.
These HiLinks are very good (tested before) , but I’ve never used them on a node, I’m more concerned about possible noise interference with that hall sensor, test before mounting everything :wink:
up to 200 mA load the voltage and ripple are fine.
X489
Wanted to use them in a nrf setup (mysensors). Some tips on fuses (thermal and slow) in this link https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
the coffee spy node project is not abandoned but @ the moment other stuff todo :sunglasses:
rs-dev21
rs-dev22
328p + RN2483 + Si7021 @ 1.5V :
high - 20mA
low- 50uA
rs-dev23-2
x509
and some fiddling with different sensors
x508
my own gateway is under reconstruction… but still this node is received by 3 other gateways
seen by 03
but probably I’m in a good location and… this 5 dbi antenna give me the best node results sofar.
x511
live03
live01
’ HOUSTON … we’ve got a problem ’ after the first night camping outdoors :wink:
problem
how’s that possible ? … a humidity over 100% , is it ME or TTN or CAYENNE or a monday morning Si 7021 sensor
noproblem
a few hours later ( 5 min interval measurements) and its getting better… we’re not 'under water ’
so my question is to you is what is the best outdoor arduino temp / humidity sensor ??
  • update … there is a sensor problem
This one I suspect:
This channel is an absolute goldmine for Espressif, ESP, sensor, protocol, Arduino IDE, library and many other related facts and fixes.
G
tnx… still a bit expensive, this afternoon I’ve tested a BME280 … positive :slight_smile:
live06
fresh start this morning with new code and a new sensor… the BME280
live09
and a new public dashboard address
live08
that silicone kit is for protecting the cheap chinese sma connectors from rusting :rofl:
BME280 seems accurate, also the ‘over 100% humidity’ didn’t occur
live10
Payloads is the same as frame counter?
yes :sunglasses:
* changed it
firstnight
it survived the first night so I leave it now and just let it do its job… for how long it will run on a normal AA battery ?
What are you using as the air purge valve? I’ve found a few but they either come in at about £15 each or I have to buy 1000 from Aliexpress…
drukcompensatie-element-m12-polyamide-lichtgrijs-wiska-evsp-12-1-stuks
here are 4 frames received by TTN gateways from the above BME280 testnode
at what RSSI level its no longer added to the application metadata ?
frames55x
this is part of the CayenneLPP buffer code from this sensor.
why is the sequence different in the metadata ? 3 4 2 1
p-meta sequence
RSSI does not determine whether data is included. Packet being from gateway received within deduplication timeout is what matters. Packets received after the timeout are discarded as duplicates.
thnx Jac.
and what determines this ’ deduplication timeout ’
… a lot of packets from that specific GW, is that possible, a ‘slow’ responding GW with a good rf signal ?
now I understand the following (a little bit) better :
during testing of this node firmware, I had one day my own gateway on, OTAA joining worked fine and when I switched my gateway off the packets were seen by 3 other gateways (sometimes only one)
next day, I had my gateway still off, I started the node again… no OTAA possible but join request visible in application ??
switched my gateway on, re started the node, no problem joining, switched off my gateway…
e voila… packets are seen by 3 gateways.
my conclusion sofar… always start your node close to a gateway :sunglasses:
